February 24, 2012, 06:18 |
digital filter
Ivana
Rep Power: 14 |
I am new in OpenFoam and I am starting my first LES simulation of a jet flame in turbulent co-flow with OpenFoam. I am wondering if someone has successfully implemented digital filter based generation of inlet data by Klein (M.Klein, A. Sadiki, and J. Janicka, J. Comput. Phys. 186:652-665,2003) and would be kind to share it? It would be very helpful. Also, is there some alternative for such kind of boundary conditions implemented already in OpenFoam 2.1.x? Thanks. Ivana |
February 27, 2012, 03:45 |
Karl-Johan Nogenmyr
Rep Power: 21 |
there is the code from LTT-Rostock, built on the idea from Kornev... there is some paper available. The code is attached here. I have a general feeling that the method of Klein is better, but I have not seen it in OpenFOAM, nor implemented it. Regards, Kalle |
February 27, 2012, 08:43 |
Ivana
Rep Power: 14 |
Thank you for this! I will try it.
Best regards, Ivana |
March 12, 2012, 06:51 |
Ivana
Rep Power: 14 |
Hi Kalle,
Could you please tell me what are: R uniform (1 0 0 1 0 1); and fluctuationScale (1 1 1)? It is give as input to turbulence generator. Second is turbulence intensity? Thanks a lot. Ivana |
March 13, 2012, 10:19 |
Karl-Johan Nogenmyr
Rep Power: 21 |
Hi!
Not too sure what the entries mean, it's been a while since I used this code. I'd guess both are related to turbulence intensity, and R meaning the reynolds stress tensor. I have no clue about dimension of these quantities. You can check the code to find out, or set up at small test case and run it to see what statistics it generates. If you find out, please post it here. K |
March 30, 2012, 10:46 |
Ivana
Rep Power: 14 |
Hi Kalle,
I have one more question. I think something is going wrong, maybe you could help me?! When I run simulation with this inflowGenerator number of spots increases in time!? Also fluctuations increase, what should not happen. Any idea what can be problem? Thanks! I. |
April 9, 2012, 16:00 |
Karl-Johan Nogenmyr
Rep Power: 21 |
Hi!
Number of spots can probably fluctuate, but if they constantly increase in time it seem strange. I did not monitor this, so I do not know too much about expected behaviour. What do you mean by increase of fluctuations? Can you sample in some points and plot the evolution of U during, say 20, integral time scales? K |
April 17, 2012, 06:00 |
Ivana
Rep Power: 14 |
Indeed number of spots can fluctuate I know. But at one point it starts only increasing, and it stays like that. So that velocity becomes almost 10 times higher where it should actually only increase for max 10%... Thanks. |
January 28, 2014, 18:03 |
#9 |
Rep Power: 12 |
Dear All,
I am also trying implementing the digitial filter method into the openfoam. Is there anybody also working on that? In the paper Klein et al 2003 Journal of Computational Physics, I have a question about why the following form of filter coefficients i.e. Eq. (14), are given (although the authors mentioned that it is only approximately valid). best flames |
January 29, 2014, 05:11 |
#10 |
Ivana
Rep Power: 14 |
I am also now looking into it, however I didn't get far yet. Would you maybe share your implementation with me? Thank you. I am not sure why they choose these filter coefficients, but from my experience the method works good with them. Regards, Ivana Last edited by IvanaS; January 31, 2014 at 06:19. |
digital filter, klein, turbulence |
Accumulating Dust on a Filter Cartridge | WalterW | CFX | 21 | May 26, 2020 07:23 |
how can use the LES filter? (laplace filter and anistropic filter) | ethan oh | OpenFOAM Running, Solving & CFD | 11 | December 26, 2018 03:37 |
Bugs in LES filter codes | yekaniyasari | OpenFOAM Bugs | 4 | February 19, 2018 07:51 |
Filter lifetime | aszbestos | FLUENT | 0 | February 13, 2002 08:59 |
DFD X CFD | Dimitrius Caloghero | Main CFD Forum | 10 | June 30, 1999 11:54 |
