error: 'Foam::T' does not have class type
Like Tree2Likes
  • 2 Post By wyldckat
Old   February 20, 2012, 20:25
Default error: 'Foam::T' does not have class type
Raymond.Leoi is on a distinguished road
double ptr_temp[OF_nCells];
for (int i=0; i<OF_nCells; i++)
ptr_temp[i] = T.field()[i];
The above is working well in OpenFOAM 1.5. But it doesn't work in OF 1.7 and an error occurs as,
solver_data.H:8:18: error: 'Foam::T' does not have class type
any idea about this problem?
Raymond.Leoi is offline   Reply With Quote
Old   February 21, 2012, 03:36
Kathrin Kissling
kathrin_kissling is on a distinguished road
can you give us a hint on how T is defined?
Thanks
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   February 21, 2012, 16:32
Retired Super Moderator
Bruno Santos
Greetings to all!
Indeed, more information would clearly make it easier to help! Usually there are two kinds of "T" on OpenFOAM applications:
  • Foam::T - this transposes a matrix.
  • ::T - this is the Temperature field defined on a solver.
Solution: don't expect the compiler to do voodoo Because if it does do voodoo, then you're probably in a whole lot of trouble...
Best regards,
Bruno
elham usefi and nepomnyi like this.
Old   February 22, 2012, 03:22
Kathrin Kissling
Hi Bruno,
do you think it got mixed up?
T.field() instead of field.T()
possible....
Best
Kathrin
Old   February 22, 2012, 04:36
Bruno Santos
Hi Kathrin,
I'm almost betting on it being that issue. I saw this problem a week or so ago, where we were basing ourselves on the discontinued Programmers Guide and came to the conclusion that "Foam::T" was a must on an equation, because the "T" field already existed.
Actually, I'm not even sure if "field.T()" still exists...
Best regards,
Bruno
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 09:07
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Flow Around a Cylinder ronaldo OpenFOAM 5 September 18, 2009 09:13
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
