February 18, 2012, 07:13 |
Change inlet velocity
Florian
Rep Power: 15 |
Hi all,
how can I change the velocity at the inlet during a calculation. For better convergence I want to start up my simulation with a low velocity value and after some iterations change it to a higher value. Is there an easy way to do this???? kind regards Florian |
February 18, 2012, 11:35 |
Philippose Rajan
Rep Power: 25 |
I guess the easiest solution would be to use something like the "timeVaryingUniformFixedValue" boundary condition available in the native OpenFOAM distribution. In your particular case, you can use this boundary condition to create a ramp of the inlet velocity to stabilize the initial part of the run. Just search for the boundary condition in the forums for more details Philippose |
February 18, 2012, 14:22 |
Florian
Rep Power: 15 |
Hi Philippose,
thx for your hint. It works fine with "timeVaryingUniformFixedValue". Here for all who are intrested: - first I wrote a file called rampe.dat, that is located in the main folder (the folder with /0, /constant, /system). This file contains: ( (0.0 (-0.75 0.0 0.0)) (25.0 (-3.79 0.0 0.0)) (50.0 (-7.58 0.0 0.0)) (75.0 (-13.64 0.0 0.0)) ) here the first number (0.0 , 25.0 ...) is the time of the simulation and the following three numbers is the vector of the velocity (-0.75 0.0 0.0). - Then I modified the boundary condition for the velocity (U): ... inlet { type timeVaryingUniformFixedValue; filename "rampe.dat" value uniform (0 0 0); outOfBounds clamp; } here outOfBounds means that after the endtime (75.0) the last value (-13.64 0.0 0.0) is retained. - At the end I started the simulation and it works Now I have a new Problem. Is it possible to change the value of omega in the MRFZones with this or any other method????? kind regards, Florian |
[swak4Foam] Scale discrete inlet velocity profile with groovyBC | cboss | OpenFOAM Community Contributions | 1 | June 20, 2010 14:02 |
inlet velocity BC | ahsan | FLUENT | 3 | July 22, 2009 05:17 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 12:21 |
UDF paraboloid velocity inlet | Ronak Shah | FLUENT | 0 | June 4, 2003 10:44 |
velocity inlet boundary | x.tang | FLUENT | 1 | May 4, 2001 10:11 |
