1D test case about condensation
Like Tree1Likes
  • 1 Post By LarsPT
Old   February 2, 2012, 03:50
Default 1D test case about condensation
kawamura
kawamura is on a distinguished road
Hi all,
I want to verify my code about condensation.
I know some test case about condensation.
but all of them are 2D or 3D problem
At first I want to try 1D problem.
Do you know 1D problem about condensation??
Could you tell me the paper with 1D condensation problem?
thanks.
kawamura is offline   Reply With Quote
Old   February 5, 2012, 17:31
Lars Kiewidt
LarsPT is on a distinguished road
Dear Kawamura,
you might want to consider the classical Stefan-Problem, named by Josef Stefan, an Austrian scientist. It is THE test case for phase change problems. I use it to validate my evaporation implementation in interPhaseChangeFoam.
You can just use Google to find some details, but I recommend the following papers:
Barba and Spiga: "Discharge mode for encapsulated PCM tanks", Solar Energy 74 (2), 2003, 141-148
Lin and Jiang: "An improved quasi-steady analysis for solving freezing problems in a plate, a cylinder, and a sphere", J. Heat Transfer 125 (6), 2003, 1123-1129
I hope this will help!
Bye,
Lars
LarsPT is offline   Reply With Quote
Old   September 6, 2013, 16:16
Default simulate evaporaton and condestion
sasan
Sasy is on a distinguished road
Dear Lars Kiewidt
I want simulate evaporation and condenstion in vertical Tube,i want use interFoam solver (or interPHase changeFoam) ,and i konw ishould modify solver by adding energy equation and mass source..can you help me...?
Regards
Sasy is offline   Reply With Quote
Old   September 7, 2013, 05:39
Lars Kiewidt
Dear Sasy,
unfortunately I'm not working on evaporation in OpenFOAM(R) right now. But I suggest that you search the forum for evaporation and boiling; you will find some threads about different implementations of the energy equation into interFoam.
Also, I would suggest that you read the PhD thesis of Kunkelmann which is freely available. He successfully uses OpenFOAM(R) to investigate boiling phenomena.
Further, I recommend the following paper:
Hardt and Wondra: Evaporation model for interfacial flows based on a continuum-field representation of the source terms. J Comp Phys 227 (2008), pp. 5871-5895.
Together with the threads in the forum this should provide a good start for your evaporation solver.
Best regards,
Lars
lowlow likes this.
Old   September 7, 2013, 16:43
sasan
Originally Posted by LarsPT View Post
Dear Sasy,
Best regards,
Lars
Dear Lars
Thank you For Reply
yes,I have phd Thesis kunkelmann,and i read the Hardt paper,but i just simualte the evaporation at the interface between fluid and gas, in which there is no bubble, and i think dont need so complicated solver same that (kunkelmann solver)...i try modifid by adding T.eqn and source term to solver...however do you have user guide how add source term and T.eqn...?
Regards,
Old   September 9, 2013, 06:21
Lars Kiewidt
Dear Sasy,
you can find some information about implementing TEqn.H into icoFoam in the OpenFOAM Wiki.
Futher, there is a good thread on the forum abotu adding temperature equation to interFoam.
Here is another report from Håkan Nilsons CFD course at Chalmers University about interFoam and temperature equation.
These sources should provide you enough information to add some kind of energy equation to interFoam.
By the way: I got all these sites by just looking for "interFoam + temperature equation" on Google.
Best,
Lars
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 07:35
rhoSimpleFoam - test case atareen64 OpenFOAM Running, Solving & CFD 5 May 1, 2011 18:17
Help Required With Simple Test Case steph79 OpenFOAM Pre-Processing 4 August 3, 2010 08:45
3D TRANSITION TEST CASE venkatesh4386@gmail.com FLUENT 0 March 9, 2009 13:04
Porous Media test case Alex FLUENT 0 April 9, 2006 09:23
