Paraview - 2d vector glyphs colored by vector direction & magnitude
Like Tree1Likes
  • 1 Post By mturcios777
Old   December 19, 2011, 18:22
Default Paraview - 2d vector glyphs colored by vector direction & magnitude
ak
newOFuser is on a distinguished road
Hi All
I have a plot of 2D vector glyphs for the velocity on a slice along the axis of a cylindrical chamber. I want to color the glyphs in such a way that the velocity vectors in the -ve direction (in the recirculation zone) are colored blue (with the shade deepening as the magnitude increases), and the velocity vectors pointing in the +ve direction are colored red.
Can this be done in paraview? Or can we only color the glyphs based on velocity magnitude?
Many thanks,
AK
newOFuser is offline   Reply With Quote
Old   December 19, 2011, 19:34
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
You can color glyphs using any variable you want. After some quick experimenting with filters, it seems like you might be able to get the result you want by:
1. Creating a glyph field from velocity
2. Applying a Calculator filter that returns the axial component of the velocity (use a dot product)
3. Apply a threshold filter that selects only positive values of component field
4. This should give you only the velocity glyphs that have a positive axial component. Change the colorbar to RBG and move the color extremes to suit your needs.
The downside to this approach is that you can only get one component (negative or positive) with this approach per dataset. If you want to show both positive and negative, components you will need to load a duplicate dataset and perform the same operations with the threshold changed to capture the opposite axial direction (or just create a second calculator attach the filters, I haven't tried this). Good luck
toolpost likes this.
mturcios777 is offline   Reply With Quote
Old   March 11, 2017, 14:51
Default Plotting velocity vectors
skmaperu is on a distinguished road
Hallo Everyone,
Can some one suggest how can i get this(picture attached) kind of velocity vector plot in paraview?
i have tried glyph. the vectors were not well organised and equally spaced.
Thanks in advance
Manikanth
skmaperu is offline   Reply With Quote
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 03:32
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
Paraview not found fusij OpenFOAM Installation 2 January 1, 2011 21:44
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 13:59
