Accessing Themo Data on a Boundary Patch
Like Tree1Likes
  • 1 Post By mturcios777
Old   December 6, 2011, 06:14
Post Accessing Themo Data on a Boundary Patch
Bill
maninthemail is on a distinguished road
Hello
Simple-ish question, this. I'm writing a boundary condition for reactingFoam. Typically, when I want to get values on said boundary, I do something like this,
const fvPatchField<scalar>& p = patch().lookupPatchField<volScalarField, scalar>("p");
const fvPatchField<vector>& U = patch().lookupPatchField<volVectorField, vector>("U");
Which works fine (see endless examples in $FOAM_SRC/finiteVolume/fields/fvPatchFields/derived).
I can't seem use this method to get the specific heat, Cp. If I try I get the error,
--> FOAM FATAL ERROR:
    request for volScalarField Cp from objectRegistry region0 failed
    available objects of type volScalarField are
followed by a list of all the variables I can access this way. Cp is not in said list.
Does anyone know how can I get Cp (and by extension other thermophysical data) on a boundary patch in this sort of context?
Many thanks in advance
maninthemail is offline   Reply With Quote
Old   December 16, 2011, 05:25
Bill
Bump. Still none the wiser. Anyone? Is this even possible? How about getting thermophysical values in the cells adjacent to the boundary?
Old   December 16, 2011, 15:17
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
I think Cp is one of those that needs to be calculated from your mixture. You might need to do something like this (this is rough pseudocode ).
fvPatchField<scalarField> Cp = 0;
forAll(Y,specI)
    Cp+=Y[speci].thePatchFieldYouWant*Cp.listOfSpecies[index for specI]
I think Cp lives in thermo somewhere, but I'm not 100% sure. Maybe look up a BC for alpha or alphat, as I think that would have access to what you need.
Zhiheng Wang likes this.
mturcios777 is offline   Reply With Quote
Old   April 13, 2012, 18:56
Nikhil
Nikhilcfd is on a distinguished road
Hello
I know this is an old post. Just in case..
I guess you need to add 'Cp' as a volScalarField in createFields.H file and update it every iteration.
Hope this helps.
Nikhilcfd is offline   Reply With Quote
boundary, capacity, condition, heat, specific
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
