Is there a corrected Gauss gradient scheme?
Like Tree5Likes
  • 5 Post By bigphil
Old   November 24, 2011, 09:18
Default Is there a corrected Gauss gradient scheme?
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
I have been looking at the accuracy of the Gauss linear gradient scheme for a simple case compared with the analytical solution, and it is exactly correct for a perfectly orthogonal mesh. But it is inaccurate if the grid is non-orthogonal.
Is there any corrected version of the Gauss linear gradient scheme where the non-orthogonality is corrected for explicitly?
I have also tried leastSquares but it seems to give strange gradients in the boundary cells. extendedLeastSquares seems to work the best but I am not entirely sure how it works.
Philip
bigphil is offline   Reply With Quote
Old   November 27, 2011, 09:54
bigphil's Avatar
Philip Cardiff
OK,
I found that you can specify explicit correction like this (as described here):
gradSchemes
   grad(U)   Gauss skewCorrected linear;
This certainly reduces the error on non-orthogonal grids, for my test cases anyway.
However, leastSquares gives me much better results on non-orthogonal grids. I was getting strange incorrect gradients in the boundary cells using leastSquares but this was solved by commenting and uncommenting a few lines in OpenFOAM-1.6-ext/src/finiteVolume/finiteVolume/gradSchemes/leastSquaresGrad/leastSquaresVectors.C.
I commented the following lines (lines 140 to 151):
        // Original version: closest distance to boundary
        //vectorField pd =
        //     mesh_.Sf().boundaryField()[patchi]
        //    mesh_.magSf().boundaryField()[patchi]
        //    *mesh_.deltaCoeffs().boundaryField()[patchi]
        //if (!mesh_.orthogonal())
	//    pd -= mesh_.correctionVectors().boundaryField()[patchi]
        //      /mesh_.deltaCoeffs().boundaryField()[patchi];
and uncommented this line (line 155):
	// Better version of d-vectors: Zeljko Tukovic, 25/Apr/2010
	// Experimental: review fixed gradient condition.  HJ, 30/Sep/2010
        vectorField pd = p.delta();
Philip
fumiya, nero235, serles and 2 others like this.
Problem in fvschemes divSchemes cannot use Gauss linearUpwind nico765 OpenFOAM Bugs 30 August 9, 2018 08:39
please help me which solver is better for my application Ger_US OpenFOAM 8 January 8, 2013 13:29
Fv scheme fuji OpenFOAM 7 December 14, 2010 00:44
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
Water pump OpenFOAM 15 ANSYS CFX 110 comparation waynezw0618 OpenFOAM Running, Solving & CFD 39 March 5, 2009 13:57
