November 16, 2011, 09:01 |
High order convective schemes
Can anyone suggest a reliable high order scheme for convective term of a tensor equation in which convective term is much more dominated? I examine upwind, limitedLinear, Gamma, SFCD, QUICK and Minmod but the results change with increasing grid resolution and it becomes unreasonable for my simple 2D geometry. Thanks in advance,
Amir |
November 16, 2011, 11:23 |
Patricio Bohorquez
Rep Power: 17 |
Hilary and Henry Weller implemented new polynomial-fit higher-order schemes (quadraticLinearFit, quadraticLinearPureUpwindFit, among others) in OF versions >= 1.6. For further details on the discretisation schemes see their papers:
http://www.met.reading.ac.uk/~sws02hs/publications/ http://www.met.reading.ac.uk/~sws02hs/AtmosFOAM/ However, spatial discretisation in OF is formally based on Taylor series including only the first two terms of the expansion. So I think that we are limited to 2nd order accuray in space. Recall that higher order schemes are difficult to be implemented in arbitrary polyhedral meshes. Regards, patricio. |
November 16, 2011, 13:14 |
#3 | |
Thanks for your reply; certainly I'll check these schemes but before I take a look over these paper, do you know about their order or stability? BTW, we have also SFCD as a second order scheme with good stability but it is said that it's very diffusive; do you have any experience with? because my convective term is very large so I prefer more diffusive schemes. Bests,
Amir Last edited by Amir; November 16, 2011 at 16:09. |
November 16, 2011, 15:01 |
Patricio Bohorquez
Rep Power: 17 |
Hi Amir, the schemes are high order with exponent very close to 2.00. Curious, for convective dominated problem on simple geometries I usually prefer low diffusive WENO schemes (order >=5). Best wishes, patricio
November 16, 2011, 16:29 |
Really!? I thought such high order schemes may lead to instability in convection dominated cases! Is there any WENO schemes in OpenFOAM?
Amir |
November 17, 2011, 07:02 |
#6 | |
Patricio Bohorquez
Rep Power: 17 |
C.-W. Shu, High order weighted essentially non-oscillatory schemes for convection dominated problems , SIAM Review, v51 (2009), pp.82-126. |
November 17, 2011, 09:11 |
#7 | |
Amir |
February 6, 2013, 18:01 |
dw
Rep Power: 14 |
Hi, what's your experience, among these higher order schemes, quadraticLinearFit, quadraticLinearPureUpwindFit, MUSCL, etc. which works better if I want to use higher order schemes for better accuracy? Say my flow is convection dominated.
Thanks a lot! |
May 16, 2013, 04:15 |
#9 | |
Rep Power: 15 |
I hope it´s correct to ask this question here. In Jasak´s PhD thesis I found the following sentences: Quote:
Can anyone explain me why it is so? Thanks Idefix |
second order schemes | marine | OpenFOAM | 67 | April 11, 2022 19:19 |
when to change discretization schemes from first order to second order | gyanesh | FLUENT | 0 | April 23, 2011 06:23 |
Higher order schemes | RameshK | Main CFD Forum | 0 | July 15, 2010 23:35 |
CFL condition for higher order schemes | Shyam | Main CFD Forum | 2 | February 14, 2008 15:24 |
High order FVM scheme .... | cfd_newbie | FLUENT | 0 | February 4, 2008 14:43 |
