October 4, 2011, 17:57 |
merging several patchs into one..
Alex
Rep Power: 16 |
Hi
I have created a mesh in gmsh, of a cyclone separator. I have exported it, and converted it using gmshToFoam, then I have run "autoPatch 14", it generated me several patches, about 15 of them. I have one inlet and two outlets, the rest of the patches can collectively be called "wall" How do I merge them alltogether under the name "wall"...? BRGDS Alex |
October 5, 2011, 10:58 |
Philip Cardiff
Rep Power: 34 |
Hi Alex,
You can use the utility "createPatch" to combine multiple patches into one. You need to copy the "createPatchDict" into your case and edit it appropriately then run "createPatch". The "createPatchDict" lives at $FOAM_UTILITIES/mesh/manipulation/createPatch/createPatchDict Then copy it into your case system directory and edit it. Philip |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[ICEM] [Student] Problem: Nodes Merging | FALCON_SR71 | ANSYS Meshing & Geometry | 8 | March 21, 2010 06:47 |
Require help in "Merging Grid Zones" | Nitesh Goyal | FLUENT | 0 | June 13, 2007 11:25 |
Help vortex merging | bin | FLUENT | 0 | March 8, 2005 20:06 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 07:46 |
