linearUpwind scheme in OpenFOAM 2.0.1 ???
Like Tree4Likes
  • 1 Post By cabul
  • 2 Post By idrama
  • 1 Post By eugene
Old   September 12, 2011, 05:24
Post linearUpwind scheme in OpenFOAM 2.0.1 ???
Andre Laß
cabul is on a distinguished road
Hello FOAMers,
i just wanted to set up a new simulation an user the following schemes:
divSchemes
default none;
div(phi,U) Gauss linearUpwindV cellLimited Gauss linear 1;
div(phi,k) Gauss linearUpwind cellLimited Gauss linear 1;
div(phi,epsilon) Gauss linearUpwind cellLimited Gauss linear 1;
div(phi,R) Gauss linearUpwind cellLimited Gauss linear 1;
div(nonlinearStress) Gauss linearUpwind cellLimited Gauss linear 1;
div(R) Gauss linearUpwind cellLimited Gauss linear 1;
div(phi,nuTilda) Gauss linearUpwind cellLimited Gauss linear 1;
div((nuEff*dev(T(grad(U))))) Gauss linearUpwind cellLimited Gauss linear 1;
but i ended up with the following message:
--> FOAM FATAL IO ERROR:
Unknown discretisation scheme linearUpwind
Valid schemes are :
41
Gamma
MUSCL
Minmod
OSPRE
QUICK
SFCD
SuperBee
UMIST
biLinearFit
blended
clippedLinear
cubic
cubicUpwindFit
downwind
filteredLinear
filteredLinear2
filteredLinear3
fixedBlended
limitWith
limitedCubic
limitedLinear
limiterBlended
linear
linearFit
linearPureUpwindFit
localBlended
localMax
localMin
midPoint
outletStabilised
pointLinear
quadraticFit
quadraticLinearFit
quadraticLinearUpwindFit
quadraticUpwindFit
reverseLinear
skewCorrected
upwind
vanAlbada
vanLeer
weighted
file: ./S-0.00/system/fvSchemes::divSchemes::div((nuEff*dev(T(grad(U)))) ) at line 40.
From function surfaceInterpolationScheme<Type>::New(const fvMesh&, Istream&)
in file lnInclude/surfaceInterpolationScheme.C at line 82.
FOAM exiting
Is there a new name for the linearUpwind scheme or has it been removed? I am quite new to OpenFOAM so maybe i made a mistake myself. Can Anyone help me?
Greeting,s
André
mm.abdollahzadeh likes this.
cabul is offline   Reply With Quote
Old   September 13, 2011, 04:59
Andre Laß
Does nobody have the same Problem?
Old   September 13, 2011, 08:00
Exclamation
Andre Laß
Hello there,
i played around with the fvSchemes for a while and ended up with the following settings, that are working for me.
gradSchemes
default cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) Gauss linearUpwindV default;
div(phi,k) Gauss linearUpwind default;
div(phi,epsilon) Gauss linearUpwind default;
div(phi,omega) Gauss linearUpwind default;
div(R) Gauss linear;
div((nuEff*dev(T(grad(U))))) Gauss linear;
Can somebody have a look at the divschemes? As far as i understood OpenFOAM 2.0.1 checks for an gradShemes right behind the definition "Gauss linearUpwind" . Is it correct to set the "default" value here, so that it uses the "cellLimited Gauss linear 1" -scheme, defined in gradSchemes?
as mentioned before, the calculation is running fine and the results look good too.
Greetings,
André
Old   September 13, 2011, 11:37
Claus Meister
idrama is on a distinguished road
In OF-2 I use linearUpwind(V) in this way:
div(phi,U) Gauss linearUpwindV grad(U);
dib(phi,k) Gauss linearUpwind grad(k);
and so on.
Cheers
mm.abdollahzadeh and s.m like this.
idrama is offline   Reply With Quote
Old   November 7, 2011, 14:05
fisch
fisch is on a distinguished road
could someome tell me what the meaning of this grad(U) in the div(phi,U) discretization is?
Thanks
rupert
fisch is offline   Reply With Quote
Old   November 8, 2011, 06:19
Eugene de Villiers
eugene is on a distinguished road
Thanks
rupert
It tells you which gradient scheme to use for the gradient part of the LUD discretisation. The specific gradient scheme is defined in the gradSchemes section. So you do not have to use "grad(U)", you can use anything you like as long as it is defined in the gradSchemes section. E.g.
gradSchemes
blahblahblah Gauss linear;
divSchemes
div(phi,U) Gauss linearUpwindV blahblahblah;
should work just fine. In all cases things like "div(phi,U)" and "grad(U)" are just identifiers, thy have no special structure or significance outside this.
Santhosh91 likes this.
eugene is offline   Reply With Quote
Old   November 8, 2011, 06:46
fisch
Thanks for the answer eugene.
now arise two questions:
1.so it should be the same as the gradient in the implicit field in the div-term?
2. what happens then if i dont specify this: just like div(phi,U) Gauss linear?
thanks a lot
Old   November 9, 2011, 06:39
Eugene de Villiers
1. As far as I know there is no fixed rule about the nature of the gradient portion of a LUD scheme. Its not like pressure and velocity flux interpolation that has to be consistent.
2. If you don't specify anything at all, the code should crash (or maybe not, I haven't checked). If you specify something with no match in the gradScemes section, it should use the "default" gradScheme entry without complaint. If no default entry is present, it should exit with an error.
Old   November 9, 2011, 07:57
fisch
thank you eugene
Second order upwinding scheme in OpenFoam subash OpenFOAM Running, Solving & CFD 4 June 20, 2012 19:28
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 06:51
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Parameter for the cubic upwind scheme in OpenFOAM JinBiao OpenFOAM 1 May 23, 2010 04:51
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 08:08
