volScalarField: how to get the coordinates of the cells
Like Tree1Likes
  • 1 Post By tonyuprm
Old   September 10, 2011, 03:59
Default volScalarField: how to get the coordinates of the cells
mrv4real
mrv4real is on a distinguished road
i ran the damBreak tutorial with interFoam and everything works fine. Now i am working on the postprocessing and would like to visualize the alpha1 file in the timestep directories.
I didn't find it in other post, could someone help me, how to get the coordinates of the cells, for which in alpha1 the scalar value is given?
Thanks a lot,
mrv4real
mrv4real is offline   Reply With Quote
Old   September 10, 2011, 16:37
Nima Samkhaniani
nimasam is on a distinguished road
could you tell me what do u want exactly?
alpha1 is in each time directory to visualize it you can just select alpha1 in paraFoam!
if you want to see the coordinate of each cell! you can use integrateVariable in paraView filter
nimasam is offline   Reply With Quote
Old   September 10, 2011, 16:43
mrv4real
using paraFoam is what i did till now, but i have to visualize the results in an existing native OpenGL application.
So i have to get the alpha value and the coordinates to write my glVertex ...
Thanks!
mrv4real
Old   September 11, 2011, 15:20
Tony
tonyuprm is on a distinguished road
You can write out information from the solver. The coordinates are accessed from a volVectorField such as "U" in this case:
U.mesh().C()[cellI]
*cellI is an index
A specific coordinate such as the x axis is accessed by:
U.mesh().C()[cellI].x()
gl,
Tony
pixarzhang likes this.
tonyuprm is offline   Reply With Quote
Old   September 11, 2011, 15:27
mrv4real
but is there also away, to get the coordinates of a cell from the files in constant/polyMesh and so on?
As I understand it, the alpha1 file has the values of the alfa-value for every cell in a timestep.
In the polyMesh are the faces, points and so on but how do I find the definition of the cells, for which the alfa value is given in alhpa1?
Thanks a lot,
mrv4real
Old   January 17, 2012, 07:21
Elvis
elvis will become famous soon enough
what about these options foamMeshToFluent , foamToFieldview, foamToEnsight,
Not to forget foamToVTK
but keep in mind that paraview is scriptable (there is some material from the OF 6th workshop "http://www.openfoamworkshop.org/2012/OFW7_Former.html currently a dead link http://www.openfoamworkshop.org/6th_...am/Program.htmto that 6th workshop") and that you can convert from VTK to many formats =>(VRML http://www.vtk.org/doc/release/5.8/html/a02298.html, STL http://www.vtk.org/doc/release/5.8/html/a01973.html, OBJ http://www.vtk.org/doc/release/5.8/html/a01303.html to name a few)
elvis is offline   Reply With Quote
interfoam, openfoam, postprocessing, volscalarfield
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
