How to calculate the gradient in the boundary cells
Like Tree1Likes
  • 1 Post By ywang
Old   August 15, 2011, 18:04
Default How to calculate the gradient in the boundary cells
Yong Wang
ywang is on a distinguished road
Hi, everyone.
I want to calculate the gradients of a volScalarField parameter F in the boundary cells. Now, I am using fvc::grad(F,gradF) to calculate the gradients in all cells, and then look up the values in the boundary cells.
Is there any other more efficient method? I just want to reduce the time used for calculating.
Thanks.
Yong
rajibroy likes this.
ywang is offline   Reply With Quote
Old   August 18, 2011, 15:56
Steven van Haren
stevenvanharen is on a distinguished road
Maybe take a look at the wallGradU utility?
Is that helpful for you?
stevenvanharen is offline   Reply With Quote
Old   August 18, 2011, 17:50
Yong Wang
Thanks.
wallGradU is using
wallGradU.boundaryField()[patchi] =-U.boundaryField()[patchi].snGrad();.
Based on the Programmers Guide, snGrad still calculate all cells in the computational region. Right?
I am also reading the code about grad and check if it's helpful.
Old   August 19, 2011, 02:55
Steven van Haren
because u use:
only the faces on this patch are calculated
Old   August 19, 2011, 05:27
Eugene de Villiers
eugene is on a distinguished road
snGrad in this context only calculates the wall normal gradient. It does so in a completely local and efficient way though. If you want to calculate the cell centred gradient for a subset of cells, I suggest you look at the code in finiteVolume/lnInclude/gaussGrad.C. This will show you the steps to calculate a gradient on a cell-by-cell basis.
eugene is offline   Reply With Quote
Old   August 19, 2011, 05:56
Steven van Haren
Ah ok, I missed the fact that cell-center gradients were required.
Old   August 19, 2011, 15:27
Wink
Yong Wang
Yes, I have read the code of gaussGrad and found there was the very thing I wanted. Thanks.
Old   August 19, 2011, 15:30
Yong Wang
It's ok. I noticed it. Thanks very much .
Old   August 30, 2011, 04:39
Yong Wang
Hi, everyone. As I want to calculate the gradient at the cells close to the boundaries. I checked the code in the gaussGrad.C:
PHP Code:
    const unallocLabelListowner mesh.owner();
    const
unallocLabelListneighbour mesh.neighbour();
    const
vectorFieldSf mesh.Sf();
Field<GradType>& igGrad gGrad;
    const
Field<Type>& issf ssf;
forAll(ownerfacei)
GradType Sfssf Sf[facei]*issf[facei];
igGrad[owner[facei]] += Sfssf;
igGrad[neighbour[facei]] -= Sfssf;
forAll(mesh.boundary(), patchi)
        const
unallocLabelListpFaceCells mesh.boundary()[patchi].faceCells();
        const
vectorFieldpSf mesh.Sf().boundaryField()[patchi];
        const
fvsPatchField<Type>& pssf ssf.boundaryField()[patchi];
forAll(mesh.boundary()[patchi], facei)
igGrad[pFaceCells[facei]] += pSf[facei]*pssf[facei];
However, in the first loop, all internal faces are calculated. So, I changed the code as:
PHP Code:
    const
    const
    const
        const
        const
        const
forAll(pFaceCellsfacei)
            if(!
mesh.isInternalFace(facei))
            else
There is no error when I compile it. But the solver will lead to unphysical results. I know there must be something wrong with pFaceCells, but have no idea to revise it. Any message from you are welcome.
Thanks in advance.
Yong
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
[mesh manipulation] How to delete selected cells from mesh and update boundary patches kaka OpenFOAM Meshing & Mesh Conversion 2 November 26, 2009 05:17
Ignore cells on partition boundary Karl FLUENT 7 May 11, 2002 23:12
Restriction on number of boundary cells !!! Haris Maharana Siemens 1 August 2, 2000 20:31
