moving reference frame - weird results!
Like Tree1Likes
  • 1 Post By alberto
Old   July 28, 2011, 04:53
Default moving reference frame - weird results!
Amir's Avatar
Amir
Amir is on a distinguished road
Hi experts,
I'm a newbie in OF and I have tried to change simpleFoam solver to achieve oscillatory reference frame, it seems that it's not a big deal but I faced weird results.
I did these changes:
scalar Pi = mathematicalConstant::pi;
		    dimensionedVector omega
		       "omega",
		       dimensionSet(0, 0, -1, 0, 0, 0, 0),
		       vector (0.0, 0.0, (amp*(2.0*Pi*freq)*Foam::cos((2.0*Pi*freq)*runTime.value())))
		    dimensionedVector alpha
		       "alpha",
		       dimensionSet(0, 0, -2, 0, 0, 0, 0),
		       vector (0.0, 0.0, (-amp*pow(2.0*Pi*freq,2)*Foam::sin((2.0*Pi*freq)*runTime.value())))
volVectorField source = (2.0*omega ^ U) + (omega ^ (omega ^ mesh.C())) + (alpha ^ mesh.C());
and:
   tmp<fvVectorMatrix> UEqn
			fvm::ddt(U)
		 + fvm::div(phi, U)
		 - fvm::laplacian(nu, U)
		 == -source
did I make any mistake?
Any suggestion or experience in this field is really appreciated.
Amir
Amir is offline   Reply With Quote
Old   July 29, 2011, 02:54
Amir's Avatar
Amir
I'm waiting for your kind response .....
Old   July 30, 2011, 04:21
Alberto Passalacqua
Oscillatory system (=unsteady) in steady state solver (simpleFoam)?
Alberto Passalacqua
Old   July 30, 2011, 05:23
Amir's Avatar
Amir
Dear Alberto,
I have added the transient term to UEqn., fvm::ddt(U); I have used unsteady simpleFoam instead of icoFoam because it's more stable and I could use larger time steps. Do you mean this procedure is incorrect?
Amir
Old   July 30, 2011, 05:34
Alberto Passalacqua
Are you doing sub-interations inside each time step? You can find it already done in pimpleFoam.
Best,
Alberto Passalacqua
Old   July 30, 2011, 05:44
Amir's Avatar
Amir
Best,
Is it really necessary? pimpleFoam is a combination of piso and simple algorithms and I don't want to engage in small time steps?!
Thanks
Old   July 30, 2011, 16:32
Alberto Passalacqua
to answer your question you should know if your system reaches a steady state or not. Since it is intrinsically unsteady, it might never reach one.
Anyway, to use SIMPLE for unsteady calculations you should:
  1. Start the time step
    1. Define UEqn
    2. Relax and solve UEqn
    3. Define fluxes
    4. Solve pEqn
    5. Correct fluxes
    6. Explicitly relax p
    7. Correct U
    8. Repeat from 1 until convergence at the given time-step is reached
  2. Advance time-step
PIMPLE is a combination of SIMPLE and PISO for unsteady calculations with larger time-steps or for pseudo-transient cases, which is why I suggested it.
Best,
Amir likes this.
Alberto Passalacqua
Old   July 30, 2011, 16:45
Amir's Avatar
Amir
Dear Alberto,
Thanks a lot for your valuable comments.
Amir
Old   August 3, 2011, 08:29
Amir's Avatar
Amir
Dear Alberto,
I did your recommandations, but now, I have a problem in convergency.
I change both pimpleFoam and also pisoFoam but convergency issues exist. I couldn't reduce initail residuals in this case, consequently, there are some differences between results and analytic solution.
Do you have any recommendation about another schemes or others?
I used different grids and also schemes but I couldn't achieve better convergency.
Old   August 3, 2011, 11:17
Alberto Passalacqua
The residual behaviour seems to show the solution is oscillating, which might indicate also a problem in the case setup.
However, you are using inconsistent numerical schemes:
  1. "linearUpwind" should use the same gradient scheme you use for the variable, so: "div(phi, U) Gauss linearUpwindV leastSquares".
  2. you should use "linear" instead than "fourth" for Laplacian.
My two cents: start with "Euler" for time integration, and use "cellLimited Gauss linear 1" for gradients, and, if necessary, upwind for convection.
Best,
Alberto Passalacqua
Old   August 3, 2011, 12:39
Amir's Avatar
Amir
Best,
Thank you very much Alberto,
Although the results are better know but there are some differences between this results and analytic one.
Anyway, I just want to ensure that whether the solution is converged or not; you said before that in unsteady cases, initial residuals should be around 0.001. Is this criteria acceptable in such cases (oscillatory nature)? (if your answer is No; how can we ensure that the solution is converged?)
Thanks again
Old   August 3, 2011, 12:53
Alberto Passalacqua
Yes, if you perform an unsteady calculation, the residuals should go down at each time step, until they reach the specified tolerance.
Residuals clearly won't do that in a steady-state solver, simply because your system does not have a steady state solution.
Best,
Alberto Passalacqua
Old   August 3, 2011, 15:35
Amir's Avatar
Amir
Best,
I imply from your answer that my result hasn't converged yet ... . I think you mean that initial residuals should oscillate around desired criteria, right? it's very difficult to reach this point even with your recommended schemes and different grids and time steps.
Old   August 6, 2011, 12:32
Amir's Avatar
Amir
Dear friends,
The problem is solved by implementing transientSimpleFoam solver instead of pimpleFoam or icoFoam.
Thanks
Amir
Old   August 6, 2011, 17:33
Alberto Passalacqua
Were you having problems with pimpleFoam? If yes, what kind of problems? There should be little difference compared to a "transient SIMPLE".
Alberto Passalacqua
Old   August 7, 2011, 04:15
Amir's Avatar
Amir
As I said before, my problem in both pimpleFoam and icoFoam was reducing initial residuals of p and U, I tried different schemes and solution controls and also time steps but I didn't achieve acceptable result particularly peak values in analytic solution; on the other hand, by transientSimpleFoam and with the same time step and schemes I achieved nice results matched with analytic one and both residuals reduced to about 0.01; I know that PISO algorithm is more precise that SIMPLE one but maybe my management for this algorithm was not efficient!
Can you explain the reason of that?
Amir
Old   August 7, 2011, 04:29
Alberto Passalacqua
Are you using the same relaxation factors in pimpleFoam and transient SIMPLE?
If the setup is the same, they should give the same result.
Alberto Passalacqua
Old   August 7, 2011, 05:22
Amir's Avatar
Amir
Of course it is; URF,schemes,... are similar, even I examine pimpleFoam with lower time steps than transienSimpleFoam but the results are not acceptable. Maybe pimpleFoam needs different schemes for better convergence and accuracy.
Thanks,
Amir
mrf, oscillatory
Enabling Acceleration in Moving Reference Frame jpo FLUENT 4 October 8, 2009 14:29
Moving reference frame sadanand FLUENT 0 February 6, 2009 00:18
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Transforming results in rotating reference frame Mark Render Main CFD Forum 1 November 27, 2002 08:20
