July 22, 2011, 12:15 |
Laplacian term in N-S equation
Diego Villa
Rep Power: 16 |
Hi All,
I have a little question on the Navier-Stokes implementation in OF. In the interPhaseChangeFoam solver the N-S equation has written as: fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(rhoPhi, U) - fvm::Sp(fvc::ddt(rho) + fvc::div(rhoPhi), U) - fvm::laplacian(muEff, U) - (fvc::grad(U) & fvc::grad(muEff)) ); My question is: what does the term "- (fvc::grad(U) & fvc::grad(muEff))" mean? In the theory that term shouldn't exist. if it's true the relationship laplacian(muEff, U)=muEff*laplacian(U)+grad(U)*grad(muEff) (see P-38 in Programmers Guide) I make some mistake? Diego |
July 26, 2011, 00:26 |
#2 | |
Mirko Vukovic
Rep Power: 17 |
Mirko |
July 26, 2011, 06:38 |
Diego Villa
Rep Power: 16 |
Hi Mirko
I'm not sure of that. Why this terms should be zero when the solution is reached? Both therms are not zero at the end, and why the inner product should be zero? Could you send me a reference about that? Thanks a lot for the replay Diego |
July 26, 2011, 07:25 |
Pablo
Rep Power: 17 |
Hi Diego,
The answer is here "http://www.cfd-online.com/Forums/openfoam/82640-interfoam-ueqn.html" and here "http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/SummerSchool2009/presentations/MitjaMorgut2009.pdf" |
July 26, 2011, 12:45 |
Diego Villa
Rep Power: 16 |
Hi Pablo
I'm agree that if the muEff is not constant the terms "div(muEff*grad(U))" and "muEff*lapalcian(U)" are different, but in the Navie- Stokes equation the first term is the right one. But as the OF Programmers Guide tell at P-38, the openfoam command laplacian(muEff,U), should be intended as the div(muEff*grad(U)) and not asmuEff*lapalcian(U), so should be not necessary split the terms in two contribute in the equation. If I say something wrong...could you say me where? Diego |
July 26, 2011, 15:36 |
Pablo
Rep Power: 17 |
July 27, 2011, 04:44 |
Anton Kidess
Rep Power: 30 |
Pablo, you have errors in the bracketing of the equations in the three lines of your eqnarray. The final result is correct though
July 27, 2011, 05:25 |
Diego Villa
Rep Power: 16 |
Thank you very much Pablo,
I found the little mistake in the brackets, but now all it is more clear. In every books i found that this therm is always hides in the source terms without explicit its. Thank you again. |
July 27, 2011, 07:56 |
#9 |
Pablo
Rep Power: 17 |
Sorry, brackets are wrong at the stress term.
Pablo |
July 20, 2012, 15:32 |
transpose term
#10 |
Ehsan
Rep Power: 17 |
Dear All
I like to ask a question: What happen to the term of transpose of (Grad (U))? To what term it is converted in equation given in "http://imageshack.us/photo/my-images/3/formulasns.jpg/" Regards Ehsan |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Large source term in species equation | MACFD | FLUENT | 4 | January 4, 2011 15:16 |
Is it possible to use divergence in the source term of an scalar transport equation? | jannnesss | CFX | 0 | January 8, 2010 20:53 |
What is the Boussinesq Term in Momentum Equation | CFDtoy | Main CFD Forum | 0 | August 11, 2008 10:56 |
bouyancy term in epsilon equation | Michael | Main CFD Forum | 1 | June 25, 1999 11:20 |
