Mesh Check fails in OpenFoam ????
Like Tree2Likes
  • 1 Post By Gitesh P
  • 1 Post By tcarrigan
Old   June 29, 2011, 09:39
Default Mesh Check fails in OpenFoam ????
Gitesh
Gitesh P is on a distinguished road
Hello everyone
I am trying to import mesh from fluent to OpenFoam with 'fluentMeshToFoam'.
Mesh is OK in fluent but in OpenFoam it getting 'Fail' message.
The message is as follow:
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
internal points: 0
faces: 33082
internal faces: 16118
cells: 8200
boundary patches: 10
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 8200
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
Pipeouterwall 60 122 ok (non-closed singly connected)
Pipetipwall 14 30 ok (non-closed singly connected)
Pipeinnerwall 100 202 ok (non-closed singly connected)
Poolbottom 72 146 ok (non-closed singly connected)
Poolwall 110 222 ok (non-closed singly connected)
symm2 8200 8483 ok (non-closed singly connected)
symm1 8200 8483 ok (non-closed singly connected)
Axis 150 302 ok (non-closed singly connected)
Outlet 30 62 ok (non-closed singly connected)
Inlet 28 58 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (0 0 0) (2.496 1.1999 0.0209429)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (4.35429e-19 -6.29787e-18 8.92786e-15) OK.
***High aspect ratio cells found, Max aspect ratio: 1616.7, number of cells 22
<<Writing 22 cells with high aspect ratio to set highAspectRatioCells
Minumum face area = 3.43495e-09. Maximum face area = 0.00638999. Face area magnitudes OK.
Min volume = 2.61256e-10. Max volume = 6.97056e-05. Total volume = 0.0311439. Cell volumes OK.
Mesh non-orthogonality Max: 0.0123584 average: 0.00145212
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.316573 OK.
Failed 1 mesh checks.
End
Can any one explain what it means and my mesh is OK or what ? Can I proceed further with this mesh or what ?
Thank you in advance !!
With regards,
Gitesh
raj kumar saini likes this.
Gitesh P is offline   Reply With Quote
Old   June 29, 2011, 11:46
Travis Carrigan
tcarrigan is on a distinguished road
Your mesh is fine. OpenFOAM is just complaining about 22 high aspect ratio cells. I believe OpenFOAM thinks any cell with an aspect ratio over 100 is too high, but this isn't an issue, it's more of a warning.
mm.abdollahzadeh likes this.
tcarrigan is offline   Reply With Quote
Old   June 30, 2011, 03:58
Gitesh
Thank you for your quick reply
So, you mean I can continue with this mesh file ?
With regards,
Gitesh
Old   June 30, 2011, 06:48
val46 is on a distinguished road
Hi Gitesh,
I agree with Travis. Your mesh fine. You can continue with it.
Regards,
Toni
"When I meet God, I am going to ask him two questions: Why relativity? And why turbulence? I really believe he will have an answer for the first." Werner Heisenberg
val46 is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[Commercial meshers] Fluent Mesh (XP32) to OpenFoam archymedes OpenFOAM Meshing & Mesh Conversion 1 April 1, 2010 06:26
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 09:59
Harpoon and OpenFoam - Mesh and simpleFoam scott OpenFOAM 4 September 4, 2009 08:48
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
