collapseEdges (after makeAxialMesh) not worked |
June 23, 2011, 18:12 |
Rep Power: 15 |
I have used makeAxialMesh to run flow in pipe at first I create 2D mesh and then Run
makeAxialMesh -axis lower -wedge frontAndBack -overwrite mesh is created successfully but when I run collapseEdges 1e-4 179.5 -overwrite I encountered bellow error Create time Create polyMesh for time = 0 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 Foam:olyMesh::calcDirections() const in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam:olyMesh:olyMesh(Foam::IOobject const&) in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/bin/collapseEdges" #6 __libc_start_main in "/lib/libc.so.6" #7 in "/home/yas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/bin/collapseEdges" Floating point exception please help me |
September 21, 2011, 11:10 |
Markus Rehm
Rep Power: 17 |
Hello
try "unset FOAM_SIGFPE" Markus |
November 17, 2011, 16:09 |
Thanks
Alex
Rep Power: 15 |
Thanks for the unset command trick, that seemed to work
[mesh manipulation] makeAxialMesh and axisymmetric flow | yassepid | OpenFOAM Meshing & Mesh Conversion | 5 | January 28, 2024 23:38 |
[Other] makeAxialMesh issue | feijooos | OpenFOAM Meshing & Mesh Conversion | 8 | October 23, 2014 06:21 |
makeAxialMesh > collapseEdges!! | billynoe | OpenFOAM | 17 | February 21, 2011 05:29 |
[mesh manipulation] CollapseEdges after makeAxialMesh utility in subversion testcase | bonzodeb | OpenFOAM Meshing & Mesh Conversion | 1 | June 5, 2009 04:24 |
Modification of collapseEdges utility | olwi | OpenFOAM Bugs | 0 | September 9, 2008 09:35 |
