June 8, 2011, 07:43 |
Multi rotating axes in OpenFOAM
Rep Power: 17 |
Dear all
I hope to simulate the flow around multi wind turbines and their interaction with each other settled on a surface (peak, plain field, and top of building). Thus, I'd like to know whether multi rotating axes is available or not in OpenFOAM 1.6-ext or 1.7.x, particluary on PimpleDyMFoam. Otherwise, I should write my own solver ? Best regards waku2005 |
June 8, 2011, 11:30 |
Hello waku,
i think it is better to use OpenFOAM1.6-extent as this version supports General Grid Interface (GGI). GGI can handle multi rotating axes, but this is stuff that only an expert like Professor Jasak can handle! read this thread => http://www.cfd-online.com/Forums/ope...mic-grids.html maybe this presentation is of partial interest for you http://www.csi.tu-darmstadt.de/media...ynamicmesh.pdf Last edited by elvis; June 8, 2011 at 11:47. |
June 8, 2011, 18:30 |
Rep Power: 17 |
Hi elvis,
Thanks a lot for your reply. Currently I work on a case of single wind turbine system. I' ll do my test case which has series of the simple turbine rotors in OF16ext. Best regards waku2005 |
June 9, 2011, 01:06 |
Can mixerGgiFvMesh handle multiple rotating zones ?
Rep Power: 17 |
Hmmmmm.
I checked the source files of the mixerGgiFvMesh library in OF16ext. I found that mixerGgiFvMesh library may have to be used in the case of SINGLE rotating Zone named "movingCells". Is there other solver (steady/unsteady) which can handle multiple rotational axes ? waku2005 |
June 11, 2011, 07:37 |
i found the latest Stuff and great overview Turbomachinery CFD with OpenFOAM http://www.personal.psu.edu/dab143/O...sak_slides.pdf http://www.personal.psu.edu/dab143/OFW6/training.htm |
June 12, 2011, 23:14 |
Rep Power: 17 |
Hi elvis
Thanks for additional information! I'll check them carefully. Last week, I have done a multiple rotor case using MRFsimplefoam and it works good. As a next step, I want to run it as an unsteady case using PimpleDyMFoam, but I should be waiting for further developments of DynamicMesh library such as immersed boundnary method. Best regards waku2005 |
April 29, 2012, 18:52 |
Jason Eason
Rep Power: 16 |
try turboFvMesh, it handles multiple transient meshes via ggi, openfoam-1.6-ext
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0 |
April 30, 2012, 06:23 |
Tibor Nyers
Rep Power: 17 |
I have run into the same problem recently - MRF with multiple rotors and want to upgrade it and run with pimpleDyMFoam. So no solution exists for this issue within OF2.1 framework? Thanks! |
April 30, 2012, 18:51 |
#9 |
Rep Power: 17 |
May 3, 2012, 09:37 |
#10 |
Niels Nielsen
Rep Power: 27 |
Commit 3edf9e06d8a5a234aac77e38fd241264c94205c6 of OF2.1.x seems to have included the possibility to have multiple rotating/moving zones.
https://github.com/OpenFOAM/OpenFOAM...241264c94205c6 I haven't tried it and there are no tutorials, so you have to figure out how to use it by yourself.
Linnemann PS. I do not do personal support, so please post in the forums. |
May 4, 2012, 03:53 |
#11 |
Tibor Nyers
Rep Power: 17 |
Thx Niels, will have a look at it!
May 16, 2012, 16:52 |
Testing pimpleDyMFoam with two rotations
#12 | |
A. S.
If somebody is interested, then I could show the results for two rotating turbines. Firstly, I copied five files from the web source mentioned above to src folder and re-compiled OpenFoam. Then, I somehow changed by intuition a file dynamicMeshDict (attached) in order to allow input of two rotations. It seems that now the program (pimpleDyMFoam) works well for two rotations. The output of the program is attached. Also, I attach animation for the pressure and a link to case files. http://www.dimensionality.info/temp/...ynamicmeshdict http://www.dimensionality.info/temp/...pledymfoam.out http://www.dimensionality.info/temp/twoturbines/twoturbines.avi http://www.dimensionality.info/temp/...nes/test2a.rar A. S. |
June 8, 2012, 22:07 |
#13 | |
A. S.
http://www.dimensionality.info/temp/...nes/onaxis.rar |
August 30, 2012, 09:23 |
#14 |
Tibor Nyers
Rep Power: 17 |
I would like to say a big thank you again for the above comments on how to define multiple solidBodyMotionFunction with AMI. I'm wondering about how to set up a case where the rotation of the solid is not predefined, instead the flow field induces the motion. In a simple wind tunnel + wind turbine setup: one specifies the inlet velocity and wants to calculate the rpm of the turbine. Thank you! |
multi rotating axes |
rotating propeller in OpenFOAM 1.6 | jiejie | OpenFOAM | 10 | January 7, 2011 02:08 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
Two rotating axes ? | Michael Palm | Main CFD Forum | 1 | September 1, 1999 08:59 |
