Does MULES::implicitsolve allow for Courant numbers > 1? |
May 31, 2011, 04:00 |
Philip Simons
Rep Power: 17 |
although there are several threads concerning the time step size for MULES VOF (in interFoam and/or interDyMFoam) I have not found a definitive answer whether you (I/OpenFOAM) can safely increase the time step size, or that anyway the max Courant number should still remain < 1? thanks, Philip |
May 31, 2011, 06:09 |
Anton Kidess
Rep Power: 30 |
No, you are still bound by the PISO algorithm to Co < 1. However, using explicit MULES you are bound by the capillary wave length, which usually gives a time step criterion dt << (Co < 1). MULES implicit somewhat relaxes that time step criterion.
May 31, 2011, 06:37 |
Philip Simons
Rep Power: 17 |
Hi Akidess,
thanks for this fast reply. I am an openfoam beginner and I did not know that all PISO (so all transient Navier-Stokes) calculations were limited by Co < 1. Do you know why this is so? Apart from losing accuracy for larger steps, I am not aware of stability issues with eg backward Euler time integration and SIMPLE (or PISO). thanks, Philip |
May 31, 2011, 06:54 |
Anton Kidess
Rep Power: 30 |
The restriction is not OpenFOAM specific, but tied to the PISO algorithm itself. If you read the derivation of the algorithm, there is a step where it is assumed that the velocity only slightly changes between time steps. This is the reason why PISO does not require relaxation and usually converges within 2-3 iterations. With SIMPLE you don't have the same time step restriction, but you'll have to do a lot more work to get a converged solution for a given time step.
You can read more about this in the original paper of the PISO algorithm: *** R. I. Issa, Solution of the implicitly discretised fluid flow equations by operator-splitting, Journal of Computational Physics, Volume 62, Issue 1, January 1986, Pages 40-65, ISSN 0021-9991, DOI: 10.1016/0021-9991(86)90099-9. (http://www.sciencedirect.com/science...21999186900999) |
May 31, 2011, 07:25 |
Philip Simons
Rep Power: 17 |
Hi again,
Thanks. I will look up the original article of Issa. I found a similar discussion under the title "Courant number and implicit treatment thread": http://www.cfd-online.com/Forums/ope...treatment.html that make things a bit clearer. At this moment I still wonder if this has been tried: Looping (within a time step) over the momentum solver + corrections does not allow for a larger time step? Philip |
courant number, implicit, mules |
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? | will.logie | OpenFOAM Programming & Development | 1 | February 16, 2011 21:52 |
CAD -> gMsh -> enGrid -> OpenFOAM Problem | AlGates | OpenFOAM | 7 | August 6, 2010 13:46 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
HELP!! Prandtl numbers in RNG k-e turbulence model | maoasis | FLUENT | 0 | April 24, 2006 11:51 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
