How to handel source term in near wall cells
Like Tree1Likes
  • 1 Post By kaifu
Old   May 11, 2011, 08:20
Default How to handel source term in near wall cells
Kai
kaifu is on a distinguished road
Hi Foamers
I have a source term Gamma on RHS of energy equation, which of course is a type of volScalarField. However this source term only appears in near wall cells and it is zero elsewhere. In physics, this source term should only come from the wall, which should be a surfaceScalarField. The flux of Gamma on the wall surface should be:
Gamma*volume of cell
However in energy equation, every term should be written in form of volScalarField (may interpolate to surface later). In such situation, when using central differencing scheme, the surface flux on boundary (wall) may be smaller than it should be. And what is worse, the interpolated value Gamma on the other side of surface will not be zero. (The near wall cells are all cubics) This is definitely not acceptable in physics. I have considered using upwind differencing scheme for Gamma. It is easy to make the flux of Gamma to be zero on the other side of cells (not wall surface) but the problem is how could I interpolate Gamma to the wall boundary? Thx.
// Kai
mm.abdollahzadeh likes this.
kaifu is offline   Reply With Quote
Old   May 15, 2011, 17:59
Kai
Some updates: My mistake. All the explicit term in energy equation will be treated like
which means there is no interpolation of Gamma onto cell faces. Only the implicit one will be interpolated.
// Kai
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
