thermo-acoustic instability in pre-mixed combustion |
May 6, 2011, 12:06 |
ak
Rep Power: 15 |
I am a new user of OpenFOAM, and would like to study thermo-acoustic instability in premixed combustion. I saw that one of the solvers for pre-mixed combustion is XiFoam. Can it be used for the purpose above? Where can I see the code where the combustion, and acoustic calculations are performed? Is there a tutorial case that studies thermo-acoustic interactions? Thank you very much! amit |
May 17, 2011, 04:54 |
XiFoam can handle it
Farshad
Rep Power: 15 |
As far as i know, i have not seen any LES simulation to obtain flame transfer function for thermoacoustic simulations. I am trying to do it , and i am trying to use GroovyBC for timevarying velocity inlets. Kind Regards, Farshad |
October 17, 2012, 11:17 |
ak
Rep Power: 15 |
Hi Farshad,
Were you able to calculate the flame transfer function? How did you define and compute it? PS: I came across some work that determines the volumetric heat release (we can use domainIntegrate) and area average velocity (patchAvergae could be used here). The TF can then be determined, and so I'm trying to implement this. Would you be kind enough to let me know how you determine FTF? Also, should the volumetric heat release be calculated over entire volume of combustion chamber, or just the flame volume? Thanks, Amit |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
On Combustion Instability | liqiang | Main CFD Forum | 1 | January 29, 2012 13:50 |
combustion thermo file | dram | Main CFD Forum | 1 | September 9, 2009 08:37 |
Combustion Instability in Gas Turbine Combustors | yoyo | FLUENT | 4 | March 16, 2008 06:39 |
COMBUSTION INSTABILITY | LORENZO | Main CFD Forum | 0 | December 6, 2004 09:25 |
