Conjugate Mass Foam Solver with reaction?
Like Tree1Likes
  • 1 Post By chegdan
Old   March 22, 2011, 15:51
Default Conjugate Mass Foam Solver with reaction?
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Hello Foamers,
I managed to combine one of my solvers that solves for time dependent passive scalar transport in a turbulent flow field for at particular species with mass transport in a solid similar to conjugateHeatFoam. This works without a hitch, but when I try to attached a simple first order reaction based on a stationary species in the solid phase it gives some errors on runtime. At first, i defined the separate species as its own field, not part of the coupledFvScalarMatrix. This gave an error:
--> FOAM FATAL ERROR:
incompatible fields for operation
[C] + [Cmetal]
I am sure it is from the source term (fvm::Sp(0.01*Csolid,Cmetal)) where i tried to couple a non coupleFvScalarMatrix field into the mix. I then decided to try and make a third region (identical to the solid region) that is overlayed on the solid region into a different mesh.
        // Add solid-side equation
        CEqns.set
            1,
            new fvScalarMatrix
                fvm::ddt(Csolid) - fvm::laplacian(Dsolid, Csolid) + fvm::Sp(0.01*Csolid,Cmetal)
	//solve the metal oxidation reaction only in the solid
        CEqns.set
            2,
            new fvScalarMatrix
		fvm::ddt(Cmetal) + fvm::Sp(0.01*Csolid,Cmetal)
I then recieved an error:
[C] + [C]
I'm assuming that the error was because I was trying to solve a system in which one variable was defined on one mesh....and another defined on a separate mesh. how does one overcome this issue?
Dan
p.s. I am using 1.6-ext
chegdan is offline   Reply With Quote
Old   March 22, 2011, 16:14
Ben K
benk is on a distinguished road
I'm pretty sure all the fields need to be on the same mesh, if they're not then you'll have to find a way of mapping the terms from one mesh to another. I would say try implementing your source term using an explicit source term first to see if that works, or even just a scalar value to see if it runs.
benk is offline   Reply With Quote
Old   March 22, 2011, 18:40
Daniel P. Combest
Mapping was not required. it turned out to be simple, but I still have to validate my results before I speak too soon. They could not be on the same mesh so I had to make another region over top the solid region with exactly the same mesh (just copied the polymesh folder). No fancy Sp, Su, or SuSp source handling was required. Only explicit definition of the source term was required. here is a snippet that I used:
        CEqns.set
            1,
            new fvScalarMatrix
                fvm::ddt(Csolid) - fvm::laplacian(Dsolid, Csolid) + k*Csolid*Cmetal
	//add the solid-side equation for another scalar in the solid
        CEqns.set
            2,
            new fvScalarMatrix
		fvm::ddt(Cmetal) + k*Csolid*Cmetal
        CEqns.solve();
Thanks for the suggestion of using just an explicit source term. That was the sticking point.
Dan
mm.abdollahzadeh likes this.
Old   March 23, 2011, 05:16
Cyp
Cyprien
Cyp is on a distinguished road
Hi!
If you want to use fvm::Sp() in the building of your matrix, you ought to inverse Csolid and Cmetal within the fonction Sp(). Indeed the second argument is the variable of the matrix:
 fvm::Sp(0.01*Cmetal,Csolid)
The solution you mentioned (that is to say to build the matrix with k*Csolid*Cmetal as a source term which is not included in the matrix also work. However, I think the use of fvm::Sp() is advised when it is possible to use it.
Bests,
Cyp
Cyp is offline   Reply With Quote
Old   March 23, 2011, 10:09
Daniel P. Combest
Originally Posted by Cyp View Post
Hi!
Bests,
Cyp
The programmer's guide states that stating a source term as (k*Cmetal*Csolid) is fully implicit (http://www.foamcfd.org/Nabla/guides/...x14-410002.4.9) and I'm not clear on the advantage of fvm::Sp() over k*Cmetal*Csolid (would be great to know is you have an idea). However, I received an error at runtime (but compiles correctly):
    [C] + [C]
    From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&)
    in file /home/dcombest/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude/fvMatrix.C at line 1207.
FOAM aborting
when using this code snippet:
        CEqns.set
            1,
            new fvScalarMatrix
                fvm::ddt(Csolid) - fvm::laplacian(Dsolid, Csolid) + fvm::Sp(k*Cmetal,Csolid)//k*Csolid*Cmetal
        CEqns.set
            2,
            new fvScalarMatrix
		fvm::ddt(Cmetal) + fvm::Sp(k*Cmetal,Csolid)//k*Csolid*Cmetal
        CEqns.solve();
however, the last code snippet:
        CEqns.set
            1,
            new fvScalarMatrix
        CEqns.set
            2,
            new fvScalarMatrix
        CEqns.solve();
compiles and executes at runtime without errors. If I substitute a simple 0.1 scalar instead of my dimensioned scalar k (read in at runtime from transport properties) then I receive an error about dimensions not matching...which is expected. I will do some more test today and make notes here if there is anything wrong. The help is much appreciated!
Dan
Old   March 23, 2011, 10:18
Cyp
Cyprien
Hi!
Look at your second equation : if you want to construct a matrix for the variable Cmetal, the second argument of your source term fvm::Sp() must be Cmetal :
fvm::Sp(k*Csolid,Cmetal)
I think it should work now.
Old   March 23, 2011, 11:44
Default Excellent!
Daniel P. Combest
That did the trick! I'm still unclear as to why the fvm::Sp() is better than just an explicit k*C*C in the equation. Is this a situation where k*C*C is collected in the b of Ax=b and fvm::Sp() collects the term into A of Ax = b? Is there an advantage? Thanks again for the help.
Dan
Old   March 23, 2011, 11:51
Daniel P. Combest
I actually found the answer on the message boards here (http://www.cfd-online.com/Forums/ope...-fvm-sp-b.html) which states:
fvm::Sp(A, B) is used for an implicit source term, so "B" is the variable you are solving for. Using A*B will leave the term on the right hand side of the equations. Depending on the sign of your source term implicit treatment can help with stability.
Old   March 23, 2011, 11:53
Cyp
Cyprien
Yes indeed, it is exactly the point! Using fvm::Sp() makes your resolution fully implicit. And most of the time the resolution is better (= better stablility).
block matrix, conjugate, mass source term
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
Conjugate Gradient Solver. Froed Main CFD Forum 0 July 29, 2005 07:29
Conjugate gradient solver for pressure. R.F. Main CFD Forum 0 November 12, 2004 12:49
