February 24, 2011, 11:13 |
interFoam and stratified flow in a pipeline
Robert Sawko
Rep Power: 22 |
Dear All,
I would like to invite some comments on the ability of interFoam to simulate stratified flow in a pipeline. My objective is to use interFoam together with cyclic boundary conditions. To validate my results I specify the flow rate and check the pressure gradient. There is a number of semi-theoretical correlations like Taitel & Dukler (1976) so I can compare with these results. I've done mesh sensitivity studies, but in the range of values I tried there was no significant effect on pressure drop or shape of the interface. There is however, a big change when I play with turbulence models. I have tried various models: kEpsilon, kOmega, LaunderSharmaKE, LamBremhorstKE and some very preliminary calculations with LES on a different mesh. Convergence, interface shape, pressure drop, velocity profiles all seem to be very sensitive to these choices but to this day I haven't really got any satisfactory results. There are some "success stories" with Launder-Sharma model in the literature for channel flow. I can give more details on the setting and results if anybody is interested. I am probably overlooking something so I would value your comments and criticism. Please, let me know if you have any thoughts or experience with similar problems. |
February 24, 2011, 19:23 |
No net flow case
Robert Sawko
Rep Power: 22 |
Sorry for putting a post again, but there is just one remarkably odd thing which I'd like to report. I've just imposed a zero mass flow rate for both phases and initialised the domain with zero velocity. With laminar model I immediately get large velocity vectors in transverse direction. All of these artefacts appear at the interface.
interfoam, stratified flow, turbulence modelling |
Stratified Two-Phase Flow | metro | OpenFOAM Pre-Processing | 31 | January 21, 2012 02:14 |
interFoam - stratified flow - problem with shear stress at interface | AnjaMiehe | OpenFOAM Running, Solving & CFD | 8 | June 14, 2010 07:49 |
Stratified Two-Phase Flow | metro | OpenFOAM | 1 | May 24, 2010 11:43 |
interFoam more Axi-symmetric two phase flow ? | Ingenierias2003 | OpenFOAM | 4 | May 10, 2010 15:39 |
Stratified flow with interFoam | sabin.ceuca | OpenFOAM Running, Solving & CFD | 0 | April 26, 2010 13:16 |
