Vof method in interFoam
Like Tree3Likes
  • 3 Post By kathrin_kissling
Old   February 16, 2011, 07:54
Default Vof method in interFoam
Andrea Ferrari
Andrea_85 is on a distinguished road
Hi all,
I am a fairly new user of openfoam 1.7. I am working with interFoam to simulate multiphase flow and i would like some explanation on how VOF method is implemented in openfoam.
Which is the equation that OF solves for alpha?
Is something like that d(alpha)/dt+div(alpha U)==0 ?
or is there an additional term to ensure the compression of the interface?
I had a look at alphaEqn.H but I did not understand that equation is solved
Is there extensive documentation on how the VOF is implemented in OF 1.7?
Thanks
andrea
Andrea_85 is offline   Reply With Quote
Old   February 16, 2011, 08:55
Bernhard
Bernhard is on a distinguished road
You can have a look here for example, some useful information and references are given:
http://www.cfd-online.com/Forums/ope...of-method.html
Bernhard is offline   Reply With Quote
Old   February 16, 2011, 08:56
akidess's Avatar
Anton Kidess
Have a look at the thesis by Henrik Rusche, it contains all the basics.
Old   February 16, 2011, 09:09
Andrea Ferrari
Thanks for the answers,
I have already read the previous posts and a little bit the thesis of Henrik Rusche. All these things are related to earlier versions of OF and I would like to know how OF is implemented now, in 1.7 version (i do not know if is the last one but i guess). It is the same?
I do not think so because I read that the VOF implemented now is different from previous versions.
Is there any documentation (paper, manual stuff like that), maybe written by who has implemented the VOF in openfoam 1.7?
thanks
andrea
Old   February 16, 2011, 11:29
Andrea Ferrari
I think, if I understand correctly, that the equation that OF solves is:
d(alpha)/dt +div(alpha*U)+div(Ur*alpha*(1-alpha))=0
Is correct?
where i can find the definition of Ur in the code and and how is it calculated?
andrea
Old   February 17, 2011, 03:30
Kathrin Kissling
kathrin_kissling is on a distinguished road
The definition is inside alphaEqn.H. Notice that we do not work on velocities but on fluxes. Tis operation is performed on the faces.
surfaceScalarField phic = mag(phi/mesh.magSf());
phic = min(interface.cAlpha()*phic, max(phic));
surfaceScalarField phir = phic*interface.nHatf();
The formula is below in the attachment.
Hope this helps.
Best
Kathrin
zhernadi, smraniaki and floquation like this.
kathrin_kissling is offline   Reply With Quote
Old   February 17, 2011, 04:42
Andrea Ferrari
Thanks Kathrin,
I copy and paste from interfacePropierties.H (not all the file):
00052                            Class interfaceProperties Declaration
00053 \*---------------------------------------------------------------------------*/
00054
00055 class interfaceProperties
00056 {
00057     // Private data
00058
00059         //- Keep a reference to the transportProperties dictionary
00060         const dictionary& transportPropertiesDict_;
00061
00062         //- Compression coefficient
00063         scalar cAlpha_;
00064
00065         //- Surface tension
00066         dimensionedScalar sigma_;
00067
00068         //- Stabilisation for normalisation of the interface normal
00069         const dimensionedScalar deltaN_;
00070
00071         const volScalarField& alpha1_;
00072         const volVectorField& U_;
00073         surfaceScalarField nHatf_;
00074         volScalarField K_;
00075
cAlpha is the compression coefficient but i really do not understand where is defined and which value is used in the calculations. Is a constant? (even if you do not define any cAlpha in constan/transportProperties.)
Thank a lot
andrea
Old   February 17, 2011, 04:50
Kathrin Kissling
Hi andrea,
it is constant and defined in the fvSolution dictionary.
The read in is in interfaceProperties.C
00146 transportPropertiesDict_(dict),
00147 cAlpha_
00148 (
00149 readScalar
00150 (
00151 alpha1.mesh().solutionDict().subDict("PISO").lookup("cAlpha")
00152 )
00153 ),
Best
Kathrin
Old   February 17, 2011, 05:14
Andrea Ferrari
Thank you very much, very helpful!
I want to ask one last thing. In the alphaEqn.H what is scalar(1)?
for (int aCorr=0; aCorr<nAlphaCorr; aCorr++)
surfaceScalarField phiAlpha =
fvc::flux
phi,
alpha1,
alphaScheme
+ fvc::flux
-fvc::flux(-phir, scalar(1) - alpha1, alpharScheme),
alpha1,
alpharScheme
Thanks a lot
andrea
Old   February 17, 2011, 05:20
akidess's Avatar
Anton Kidess
Exactly what it says - a scalar with the value 1. OpenFoam is smart enough to do the arithmetic operation for the entire volField even if one of the operands is a scalar value.
Old   February 17, 2011, 05:41
Andrea Ferrari
Very simple!
Thanks again
andrea
VOF Interfacial Area - 2D/3D Reconstruction Method Greg Perkins Main CFD Forum 2 September 10, 2012 05:05
How to apply VOF method? yeeking86 CFX 7 August 23, 2010 19:24
slop in Hirt's VOF method GCM Main CFD Forum 0 July 28, 2009 16:44
Are the VOF results of interFoam grid independent asaha OpenFOAM Running, Solving & CFD 1 June 26, 2009 05:27
VOF method on inter-tank transfer Louis FLUENT 0 March 14, 2006 10:28
