boundaryField vs. internalField
Like Tree1Likes
  • 1 Post By AlmostSurelyRob
Old   January 14, 2011, 08:23
Default boundaryField vs. internalField
Sebastian Lang
sebonator is on a distinguished road
Hi there,
maybe this sounds a bit like a stupid question, but the answer is not clear to me:
Can you tell me, what the 'boundaryField', like it is returned for example from a volScalarField by
volScalarField.boundaryField();
really is? Are those values the values of the cells that are located next to the boundary (=> The very first cells when you move from the patch into your field???) or are those values the values of the faces which lie on the patch?
This makes a difference!
Thanks in advance,
Greetings Sebastian
sebonator is offline   Reply With Quote
Old   January 14, 2011, 08:42
akidess's Avatar
Anton Kidess
I'm pretty sure it's the patch value. The near-patch cell values can be read by patchInternalField I think.
Old   January 14, 2011, 09:50
Talking Problem solved!!!
Sebastian Lang
Thanks Anton!
Greetings Sebastian
Old   January 14, 2011, 10:45
Robert Sawko
AlmostSurelyRob will become famous soon enough
As suggested above through this construct you can access patch values. You can also reinforce it with an id in a following way
q.boundaryField()[i]
where i is the ID of your patch as stated in blockMeshDict.
Another example is:
 sum( q.boundaryField()[i] * mesh.Sf().boundaryField()[i] );
which will calculate a surface integral of quantity q on patch i.
Hope that helps.
mm.abdollahzadeh likes this.
AlmostSurelyRob is offline   Reply With Quote
Old   January 14, 2011, 11:53
Ben K
benk is on a distinguished road
Along the same line of questioning, how can I access the value at a corner of a 2D mesh?
benk is offline   Reply With Quote
Old   January 17, 2011, 05:45
akidess's Avatar
Anton Kidess
I don't think you can, because values are not stored on vertices. You will have to manually find the corner cell and then interpolate the appropriate face values to get something at the corner.
Old   January 17, 2011, 09:13
Sebastian Lang
Hi Ben,
I don't really know a correct answer for your question, but I doubt that there is a method in volVectorField or volScalarField that returns such a "corner" value.
Maybe you can create the value with some "if"-construct, because such a corner cell would be defined as "a cell that has two different patches on two of her faces". I can't tell a proper implementation, but maybe that's something you can start from!
But as Anton already mentioned, you will have to separate between cell-centre-values and face-centre values.
Hope that helps,
Greetings Sebastian
Old   January 24, 2011, 16:25
Mirko Vukovic
mirko is on a distinguished road
Another example is:
Hope that helps.
I am writing a boundary condition (I will use oscillatingFixedValue as guide) in a radiation problem, which calculates Qr (see fvDOM.c). I want to get the patch value using the procedure you describe.
But, how can I get hold of Qr? I am assuming it is a property of the fvDOM object. I'm not sure how to get hold of it in my code.
Thank you,
Mirko
mirko is offline   Reply With Quote
Old   January 24, 2011, 16:48
Robert Sawko
Hello Mirko,
I have no experience with radiation models in OpenFOAM. Also, I am not sure what do you mean by patch value. Do you want to use a value for each face on the patch or just some sort of integral?
In the latter case I believe that the code you're looking for
dimensionedScalar result =
sum(fvDOMInstance.Qr().boudaryField()[patchIndex] *
mesh.Sf().boundaryField()[patchIndex])
where fvDOMInstance is simply an instance of the fvDOM class.
Old   January 24, 2011, 16:53
Mirko Vukovic
Hello Mirko,
Yes, I think that is what I am after. But how to get to the fvDOMinstance? :-)
Thanks,
Mirko
Old   January 24, 2011, 17:43
Robert Sawko
Right, now I see your problem and I am afraid can't claim any competence in OpenFOAM radiation models.
Perhaps you could look for some hints in
/$FOAMSRC/thermophysicalModels/radiation/derivedFvPatchFields/wideBandDiffusiveRadiation/wideBandDiffusiveRadiationMixedFvPatchScalarField. C
/$FOAMSRC/
thermophysicalModels/radiation/derivedFvPatchFields/greyDiffusiveRadiation/greyDiffusiveRadiationMixedFvPatchScalarField.C
Both of these codes are executing Qr and using fvDOM. Let me know if you find an answer.
boundary field, boundary patch
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 07:54
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 09:07
Problem with internalField mecbe2002 OpenFOAM 1 April 24, 2010 11:57
buoyantSimpleRadiationFoam msarkar OpenFOAM 0 February 15, 2010 07:22
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 05:53
