temperature boundary condition with heat transfer coefficient
Like Tree1Likes
  • 1 Post By sebonator
Old   December 9, 2010, 12:14
Default temperature boundary condition with heat transfer coefficient
Sebastian Lang
sebonator is on a distinguished road
Hi there!
I am sorry for asking such a stupid question, but I invested a lot of time in searching but didn't find the answer:
How can I give the temperature field of a solid region in the chtMultiRegionFoam-Solver the trivial boundary condition
q = alpha * ( T - T_inf )
I am absolutely sure that this is possible, because this is absolutely one of the most basic boundary conditions when dealing with heat transfer problems!
There is a boundary condition "wallHeatTransfer" that seems to do what I want, but it belongs to the thermophysicalProperties-library. I am confused about that, because I thought this library is only used for the fluid regions?!?!
If this BC is the way to do that, then what should I write into the thermophysicalProperties-Dictionary? I think treating a solid as an incompressible fluid is a bit strange, isn't it?
Thanks for any replies!
Greetings Sebastian
sebonator is offline   Reply With Quote
Old   December 9, 2010, 12:18
Ben K
benk is on a distinguished road
As far as I can tell, the easiest way to do this is to install groovyBC, otherwise you'd have to make your own BC.
Check out this thread: http://www.cfd-online.com/Forums/ope...acianfoam.html
benk is offline   Reply With Quote
Old   December 9, 2010, 17:04
Talking
Sebastian Lang
Thanks a lot benk!
This solution in fact is a bit more complicated than I expected for such a "standard" boundary condition, but I am happy as long as my simulation runs ;-)
I already spent so much time in learning the usage of this chtMultiRegionFoam-Solver, because I currently absolve my internship in a company and have to test OpenFOAM for them. They want me to check out, if the program is usable for a real industrial case like the simulation of heat transfer through a whole pump, but I really think that the lack of documentation will keep OpenFOAM from getting important in real industrial applications!
But well, as I said above, thanks a lot for your help!
Greetings Sebastian
Hr_kules likes this.
chtmultiregionfoam, heat flux, heat transfer coefficient
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
heat transfer with constant wall temperature Marco FLUENT 0 December 8, 2005 08:16
heat transfer coefficient Jorge Facao FLUENT 0 June 4, 2004 17:35
