Using "patchIntegrate" command to calculate patch flow rate
Like Tree1Likes
  • 1 Post By flowman
Old   November 7, 2010, 14:07
Question Using "patchIntegrate" command to calculate patch flow rate
maysmech's Avatar
maysmech is on a distinguished road
Hello Foamers,
I want to calculate flow rate of a patch. i read forum and found i should use "patchIntegrate" for phi to obtain flow rate of patches.
How can i use it?
Thanks in advance,
maysmech is offline   Reply With Quote
Old   November 7, 2010, 19:57
Aidan
flowman is on a distinguished road
In the case folder you simply run:
patchIntegrate <fieldName> <patchName>
Replace <fieldName> with phi and <patchName> with the name of the patch that you want to calculate the flow rate on.
ShashiDeSilva likes this.
flowman is offline   Reply With Quote
Old   November 7, 2010, 23:18
maysmech's Avatar
Thanks you very much Aidan,
How can i use it in parallel processing?
Old   November 7, 2010, 23:30
Aidan
if you enter the command
patchIntegrate -help
you will get the following output
Usage: patchIntegrate <fieldName> <patchName> [-latestTime] [-time ranges] [-parallel] [-constant] [-noZero] [-case dir]  [-help] [-doc] [-srcDoc]
As you can see, there is a parallel flag. I've never used it myself but I'm sure it works!
Old   November 9, 2010, 03:39
maysmech's Avatar
Thanks.
It doesn't work for me.
target flow rate: varying results Ryan FLUENT 3 January 9, 2008 14:54
mass flow rate error Masood FLUENT 0 May 22, 2005 01:32
How to calculate the mass flow rate with UDF ? HP FLUENT 0 January 10, 2005 20:38
Target mass flow rate Saturn FLUENT 0 December 10, 2004 05:18
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
