Setting mass flow rate boundary condition
Like Tree20Likes
  • 11 Post By philippose
  • 1 Post By maysmech
  • 5 Post By philippose
  • 1 Post By linnemann
  • 2 Post By Dadou
Old   October 26, 2010, 12:24
Question Setting mass flow rate boundary condition
maysmech's Avatar
maysmech is on a distinguished road
Dear Foamers,
How can i define mass flow rate boundary instead of velocity for a case simulation in OpenFOAM?
maysmech is offline   Reply With Quote
Old   October 26, 2010, 14:41
Philippose Rajan
philippose will become famous soon enough
Hello there,
A Good Evening to you :-)!
To specify a flow rate instead of a velocity, you can use the boundary condition:
flowRateInletVelocity
For an example of how to use it, check the following file in the tutorials folder of OpenFOAM:
/compressible/rhoPimpleFoam/angledDuct/0/U
Hope this helps.
Have a nice day ahead!
Philippose
koooje, pfhan, m_mousavi88 and 8 others like this.
philippose is offline   Reply With Quote
Old   October 26, 2010, 15:53
maysmech's Avatar
Dear Philippose,
Thank you very much for your answer.
two questions:
i think it is suitable for inlet patches, isn't it? i need sth for outlet patch.
if i use it for inlet, in tutorial file P type is set to zeroGradient. can we suppose it in flow which comes from a duct as zeroGradient when (as you know) it has pressure drop across the duct?
Best regards,
Maysam
koooje likes this.
Old   October 26, 2010, 15:55
maysmech's Avatar
And 3rd question:
How can i calculate mass flow rate of a patch by using paraView?
Old   October 26, 2010, 19:10
Philippose Rajan
Hi again,
* If I remember right, you can use the flowRateInletVelocity patch as an output simply by changing the sign of the flow rate value, to indicate that it is flowing out of the domain.
* Normally, you cannot specify a fixed velocity (flow rate) and a pressure on the same boundary..... this is why, you need to provide a zeroGradient boundary condition for the pressure when you supply the flow rate as an input parameter. .... I am not sure what you imply by a pressure drop across the input boundary in a duct.
* Paraview has a filter which lets you integrate a variable over a surface (I think the filter is called Surface Flow).... this should give you the flow rate, however, I remember that I had an issue trying to interpret the output of this filter..... try it out anyway.... it basically calculates the dot product of a flow field and the normal vectors of the surface.
Philippose
soheil_r7, mwaqas, wmrlak and 2 others like this.
Old   November 4, 2010, 01:55
maysmech's Avatar
As i understand, the flow rate boundary is same as setting a fixed value velocity in the boundary and this is not useful for cases which our velocity profile is not uniform.
Old   November 4, 2010, 02:20
Philippose Rajan
The question then is, what exactly did you want to do?
a. Specify a uniform flow rate at the input
b. Specify a uniform velocity at the input
c. Specify a non-uniform velocity profile at the input (spatially non-uniform across the input patch)
d. Specify a non-uniform flow rate at the input (spatially non-uniform across the input patch)
In case it was (d), how would you specify the flow rate? would it be the flow rate through each patch element face?
In which case it would be something like specifying a non-uniform velocity profile where v_face = Q_face / A_face
For specifying a parabolic Inlet velocity, you have the boundary condition: "parabolicVelocity"
In addition, you could try to create a customised non-uniform velocity / flow inlet using the "groovyBC" library.
Philippose
Old   November 4, 2010, 02:58
maysmech's Avatar
Thanks Philippose,
I want it for an outlet patch that is not uniform velocity. for example a T-junction geometry with two different outputs and i want control rate as 20% and 80% in outlets by setting mass flow rate.
Best,
Old   December 16, 2011, 04:53
Bernhard
Bernhard is on a distinguished road
Hi Maysam,
Did you ever get this to work? I am also interested in such a boundary condition with a mass flow rate that is dictated, but also keeps in some way the zero gradient condition there.
Bernhard is offline   Reply With Quote
Old   August 21, 2013, 04:23
H.Martens
Spidermohaa is on a distinguished road
I am, too!
Spidermohaa is offline   Reply With Quote
Old   August 21, 2013, 04:39
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
you can use something lige this (OF22)
for inlet use zeroGradient for outlet use this
   outlet
        type            flowRateInletVelocity;
        volumetricFlowRate    constant -0.1; // m3/s, negative sign means out of the domain
        value           uniform (0 0 0);
mwaqas likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   February 6, 2014, 03:37
Mehdi GHOZALI
Dadou is on a distinguished road
Originally Posted by linnemann View Post
Hi
   outlet
So if I understood well, if we have a flow in the inlet and outlet (going out of the domain) we need to set inlet = zeroGradient and then put a flow in the outlet ??!!
Thank you
mwaqas and wmrlak like this.
Dadou is offline   Reply With Quote
Old   May 28, 2015, 10:49
James F.
NoradFirst2 is an unknown quantity at this point
I have a quite similar problem and I cannot find the answer.
I am using buoyantPimpleFoam currently.
I have
inlet : U is fixedValue / P is zeroGradient / T is fixedValue
suction_outlet : U is zeroGradient / P is fixedValue (0.995e5) / T is zeroGradient
secondary_outlet (actually, suction_outlet sucks air from this patch in addition to air from the inlet) : U is zeroGradient / P is fixedValue (1e5) / T is inletOutlet (calculated with internalField - to prevent air coming inside the domain from this patch being at 0K).
I'd like to change my suction BC to have a given volumicFlowRate rather than fixed pression which is causing instability. I tryed something like :
   U
suction
        volumetricFlowRate    constant -130; // m3/s, negative sign means out of the domain
P
suction {type     zeroGradient}
But then, the velocity field is 0 nearby, suction is behaving like the outlet...
Do you have any advice? Thanks!!
PS : What does the line " value uniform (0 0 0);" in flowRateInletVelocity stands for?
EDIT - PB SOLVED: I had a unit problem.
NoradFirst2 is offline   Reply With Quote
Old   June 15, 2016, 03:59
Fatemeh
fatemehfarshi62 is on a distinguished road
Originally Posted by philippose View Post
Hello there,
Hope this helps.
Philippose
Hi!
I have a similar problem. Would you please tell me, when defining flowRateInletVelocity, do we have to enter discharge massFlowRate or discharge/area? I have determined it like this: type flowRateInletVelocity;
massFlowRate constant 0.2512;
but it has another part, value, what doest it want?
also, would you please tell me, if I define a slip wall for atmosphere, I should define value uniform (0 0 0) for it? why? Not that I have an open channel which I want to specify slip wall instead of atmosphere in the surface.
Thanks
fatemehfarshi62 is offline   Reply With Quote
Old   December 6, 2018, 06:42
Default Cyclic mass flow rate
  #15
Calum Roberts
CalumR is on a distinguished road
Hi there,
I am trying to set up a cyclic case where a specific mass of water passed through the system each second. Because my patch type is cyclicAMI i cannot use the flowRateInletVelocity type. Does anyone have any ideas on how to do this?
Any help would be appreciated!
Calum
CalumR is offline   Reply With Quote
Old   July 22, 2021, 12:30
Masoumeh
ms.hashempour is on a distinguished road
Originally Posted by CalumR View Post
Hi there,
Calum
cyclic does not work in this condition. I suggest to change it. with discharge as negative and positive value you can run your model.
ms.hashempour is offline   Reply With Quote
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
Target mass flow rate Saturn FLUENT 0 December 10, 2004 05:18
Mass flow boundary condition Síle FLUENT 0 June 12, 2003 08:30
Constant mass flow rate / choking outlet bounardy condition Min Zhu Main CFD Forum 1 September 29, 1998 16:33
