August 30, 2010, 12:07 |
Binary files
Rep Power: 16 |
I have 2 separate questions regarding OpenFOAM binary output: 1) Is there a flag in the OpenFOAM file structure that can tell me whether binary data is written in single or double precision? 2) Also, is there a way to tell whether big or little endian is used to write the binary data in the file? Thanks. -amtri |
September 17, 2010, 02:05 |
#2 | |
Alberto Passalacqua
Rep Power: 36 |
OpenFOAM compiles in double precision mode by default. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
March 15, 2011, 05:15 |
#3 | |
BastiL
Rep Power: 20 |
Regards Bastian |
March 16, 2011, 00:43 |
Alberto Passalacqua
Rep Power: 36 |
What is the logic behind this? You would lose the double precision used in the mesh immediately at the first operation you force to be single precision.
March 16, 2011, 03:59 |
#5 | |
BastiL
Rep Power: 20 |
The accuracy differences between SP and DP for my cases are very small. I can reproduce this behaviour with the ASCII-option: Saving my mesh with 6 digits prevents simpleFoam from running both in SP and DP but saving with 10 digits makes simpleFoam to run in both SP and DP. However SP is about 40% quicker and I don't really want to save in ASCII as it doubles the required diskspace. Regards Bastian Last edited by bastil; March 16, 2011 at 04:17. |
March 16, 2011, 19:35 |
Alberto Passalacqua
Rep Power: 36 |
You can simply save the mesh in compressed format as ASCII, and then switch to binary for the data.
Best,
March 17, 2011, 10:01 |
Olivier
Rep Power: 18 |
hello,
On some testcase i did some time ago, with a lot of time step saving, I've got the best speedup with compressed ascii file, binary file where little slower, and ascii file much slower. so try compressed file ! olivier |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 14:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 09:42 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
