August 30, 2010, 05:30 |
How can i plot variables over time?
Dear Foamers,
I want plot velocity (U mean, fluctuation and U) over time in the case which is solved with pisoFoam. How can i do this in paraView? when i choose plot global variable over time none of variables are available to select for y direction. |
August 30, 2010, 07:31 |
yvin
Rep Power: 16 |
I think the best is to use the sampleDict to extract data over times and write a script to bring all the informations in one file. After that, plotting is easy with gnuplot.
August 30, 2010, 10:34 |
#3 | |
if i understand your meaning, i should make a sampleDict file in system folder. but i have run my case now and i want using paraView software. your suggestion seems good but need to run the case again. is there another way to plot a variable of one point versus time? |
August 30, 2010, 10:35 |
Chris Sideroff
Rep Power: 22 |
You might want to check out pyFoam: http://openfoamwiki.net/index.php/Contrib_PyFoam .
There's one specifically for what you're asking for: http://openfoamwiki.net/index.php/Co...mSamplePlot.py |
September 1, 2010, 12:19 |
#5 | |
yvin
Rep Power: 16 |
September 17, 2010, 02:01 |
Alberto Passalacqua
Rep Power: 36 |
Also, paraview can do that.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
September 17, 2010, 11:33 |
Alberto Passalacqua
Rep Power: 36 |
There is a filter called "Plot selection over time"
September 22, 2010, 23:20 |
#9 | |
Rep Power: 18 |
[OpenFOAM] How to plot flow rate over time with Paraview | sekunda | ParaView | 17 | July 23, 2020 14:14 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 10:15 |
how to plot a variable with respect to time | nandiganavishal | OpenFOAM Running, Solving & CFD | 0 | March 15, 2009 21:02 |
choosing a time frame to present a plot | AAA | FLUENT | 1 | July 29, 2007 19:41 |
flow time plot units | alex | FLUENT | 0 | July 2, 2007 14:38 |
