A question about object angular orientation
Like Tree2Likes
  • 2 Post By daveatstyacht
Old   August 23, 2010, 11:16
Default A question about object angular orientation
Dave
daveatstyacht is on a distinguished road
Hi all,
I was wondering if someone knew how to extract and log the orientation of a 6DoF object? I am interested in being able to record the pitch, roll, and yaw angles of a ship model (preferably in degrees, but radians is fine too). As far as I can discern the orientation is stored in a tensor Q which is used among other things in the 6 DoF motion solvers. I was wondering how you modify what is logged and what files must be modified (both runtime and or OF files) so that I can get a file similar to the "forces" file output of the force function group? Any help would would be greatly appreciated.
-Dave
federicabi and chliu like this.
daveatstyacht is offline   Reply With Quote
Old   June 1, 2016, 07:47
Federica Biano
federicabi is on a distinguished road
Originally Posted by daveatstyacht View Post
Hi all,
-Dave
Hi Dave,
I know this is a very old post but your question is very interesting. did you find a way to do that?
Best regards
Federica
federicabi is offline   Reply With Quote
Old   June 1, 2016, 11:52
mo_na's Avatar
Mona
mo_na is on a distinguished road
Hey Federica,
check out this thread:
http://www.cfd-online.com/Forums/ope...tml#post602859
Hope that helps
mo_na is offline   Reply With Quote
Old   June 9, 2016, 06:11
Federica Biano
Originally Posted by mo_na View Post
Hey Federica,
Hope that helps
Hi mona!
Thanks for your reply! The post was really helpful. Now I'm interesting in doing it in run time, I mean I need to extract the orientation from the log file in run time to use it in my modified restraint library.
Any suggest?
Thanks in advance
Federica
6dof, angles, orientation, ship
Changing orientation of object in Paraview Jochem OpenFOAM 0 July 28, 2010 05:52
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 16:49
a question of open ".cas" and ".dat" files fanzhong Meng FLUENT 4 May 15, 2006 12:40
