Unstable spray for small mesh size (dieselFoam)
Like Tree1Likes
  • 1 Post By schmidt_d
Old   August 13, 2010, 15:11
Default Unstable spray for small mesh size (dieselFoam)
namCFD is on a distinguished road
I could not figure out the reasons for the water spray in my simulation becoming unstable when I make the mesh size smaller. I hope the community can point me in a direction for diagnosing this issue. I have included a video for your viewing. If you need the files, I can post them also. The mesh size is 2.5 cm x 2.5cm x 2.5cm.
Following is my set up:
+ dieselFoam for water spray (10 micron min and 50 micron max droplet dia)
+ nozzle dia = 3 mm
+ injection velocity = 10 m/sec
+ mass flow rate = 0.04241 kg/sec
+ injection pressure = ~1.5 bar
+ room size = 4 m long x 2 m high x 2 m wide with ambient air temp (300K ) and ambient pressure
I used VirtualDub (free and portable video editing software) to compress and crop the file.
Thank you for your help.
Nam
namCFD is offline   Reply With Quote
Old   August 13, 2010, 16:43
Default more parcels
David P. Schmidt
schmidt_d is on a distinguished road
Without looking at your case in detail, I have a suggestion. You need to greatly increase the number of computational parcels injected into your domain (this doesn't change the injected mass, but rather represents the mass with a greater statistical fidelity).
The reason is that, as a cell gets smaller, the source terms of cells in densely loaded regions get hit with huge noisy source terms from the droplets at are proportionately larger.
At a minimum, you want the number of parcels to go up proportional to the cell count. Even that is not really sufficient.
See:
David P. Schmidt, “Theoretical Analysis for Achieving High-Order Spatial Accuracy in Lagrangian/Eulerian Source Terms,” Int. J. of Numerical Methods in Fluids, 52(8), 2006.
and slightly related:
Sasanka Are, Shuhai Hou, David P. Schmidt, “Second Order Spatial Accuracy in Lagrangian-Eulerian Spray Calculations,” Numerical Heat Transfer, Part B: Fundamentals, 48(1), pp. 25-44, 2005.
-DPS
amolrajan likes this.
schmidt_d is offline   Reply With Quote
Old   August 13, 2010, 16:51
See:
-DPS
Thank you very much for your help. I will check out those articles and follow your suggestions. I will also try to post the case files.
Nam
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 12:22
unstructure mesh size control near to wall using gambit lalit kumar FLUENT 4 July 6, 2010 16:13
Gambit Unstructed (Tet) Mesh - size control newbie FLUENT 3 August 26, 2008 12:38
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
