calculate mass flow rate on face OpenFoam
Like Tree3Likes
  • 1 Post By Robat
  • 2 Post By nuovodna
Old   August 4, 2010, 06:52
Default calculate mass flow rate on face OpenFoam
toto
ronaldo is on a distinguished road
Dear All,
could some please tell me how to calculate mass flow rate on face OpenFoam. I need it for a Presentation.
Thanks in advance,
Ronaldo
ronaldo is offline   Reply With Quote
Old   August 5, 2010, 06:27
Robert Langner
Robat is on a distinguished road
Hi ronaldo,
you can get the mass flux by volume flux * density.
The volume flux you can read out directly from the result directories (0.*). You just need to know the number of your expected face. But normally the mass flux is needed for a whole patch (to be independent from the cell resolution). In these cases you can use the function:
patchIntegrate phi <patchName> -case <caseName>
There are more functions which may provide you a more elegant way:
http://openfoamwiki.net/index.php/Co...unctionObjects
Or if you got OF 1.6, you can simply use the mass flow functions :-))
Regards,
Robert
mm.abdollahzadeh likes this.
Robat is offline   Reply With Quote
Old   August 6, 2010, 09:47
toto
Thank you so much Robat,
I have tried, but it not works.This is the message
Table of functionObjects is empty
From function functionObject::New(const word& functionType, const Time&, const dictionary&)
in file db/functionObject/functionObject.C at line 75.
Old   August 9, 2010, 11:21
Emanuele
nuovodna is on a distinguished road
You can use calcMassFlow utility
http://openfoamwiki.net/index.php/Contrib_calcMassFlow
mm.abdollahzadeh and nanavati like this.
nuovodna is offline   Reply With Quote
Old   August 20, 2010, 08:05
Default compatible with 1.6 or 1.7
Raghavendra
raagh77 is on a distinguished road
Send a message via Yahoo to raagh77 Send a message via Skype™ to raagh77
Is this compatible with 1.6 or higher vesion?
I tried to compile with 1.6 and ended up with some errors.!
Regards
Raghu
raagh77 is offline   Reply With Quote
Old   August 27, 2010, 06:26
Emanuele
it works on my 1.7.0 installation. Use the attached tar.gz : it contains a few modifications to make compatible with newer version
Old   August 27, 2010, 06:56
Default thanks.. It worked
Raghavendra
Hi Emanuele,
Thanks for the attached file.. I was able to compile in OF 1.7
Regards
Raghu
Old   November 8, 2019, 01:10
Default Compiling Error of calcMassFlow utility
Mondal131211's Avatar
Mondal
Mondal131211 is on a distinguished road
Originally Posted by nuovodna View Post
Hi Nuovodna,
I do not know whether you are still here or not. I tried to compile this utility but it shows the following error in OpenFOAM 3.0.1. Do you know the reason for that?
HTML Code:
calcMassFlow.C: In function ‘int main(int, char**)’:
calcMassFlow.C:169:31: error: ‘endTime’ was not declared in this scope
     for (label i=startTime; i<endTime; i++)
Anyone can help me if that is known to you. Thanks in advance.
Cheers
Razon
Mondal131211 is offline   Reply With Quote
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 13:19
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
dieselFoam- Density and mass flow rate Rachel OpenFOAM Running, Solving & CFD 1 July 20, 2009 07:36
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
How to calculate the mass flow rate with UDF ? HP FLUENT 0 January 10, 2005 20:38
