chtMultiRegionFoam Tutorial
Like Tree1Likes
  • 1 Post By wyldckat
Old   June 8, 2010, 13:21
Default chtMultiRegionFoam Tutorial
m.nichols19 is on a distinguished road
While attempting the multiRegionHeater chtMultiRegionFoam tutorial I encountered an error that I cannot resolve.
After running the Allrun file, the log.changeDictionary.bottomAir file displays the following:
Create time
Create mesh bottomAir for time = 0
Cannot find file "points" in directory "constant/bottomAir/polyMesh"
From function Time::findInstance(const fileName&, const word&, const IOobject::readOption)
in file db/Time/findInstance.C at line 148.
FOAM exiting
Any help would be greatly appreciated.
m.nichols19 is offline   Reply With Quote
Old   June 8, 2010, 18:23
I solved the error by replacing line 18 of the Allrun script:
changeDictionary -region $i >& log.changeDictionary.$i
should be replaced with
changeDictionary -region $i > log.changeDictionary.$i 2>&1
I hope that helps if you encounter the same problem.
Now I have a new dilemma. The various volume fields will not show up in ParaView. Suggestions?
Old   June 8, 2010, 19:14
Retired Super Moderator
Bruno Santos
Greetings Matt,
Quick solution: on the first line of the Allrun script, change "/bin/sh" to "/bin/bash".
Long explanation - The problem you are facing is quite simple: all of the tutorial scripts use "/bin/sh", but in each Linux distro, sh is linked to bash, dash, ash, ksh or any other shell. But unfortunately, the Linux distro where the tutorials were prepared, sh points to bash, thus the scripts respect mostly the bash syntax, while other systems that use another shell can't handle that same syntax; e.g.: Ubuntu that has dash as default sh.
If you want to change all tutorial scripts to use bash instead of sh, you can run this code in a terminal with OpenFOAM environment activated:
Originally Posted by http://code.google.com/p/openfoam-ubuntu/
cd $FOAM_TUTORIALS
find $FOAM_TUTORIALS/ -name "All*" | \
while read file
do
    mv "$file" "$file.old"
    sed '/^#!/ s/\/bin\/sh/\/bin\/bash/' "$file.old" > "$file"
    rm -f "$file.old"
done
echo "Fix up bash done"
Best regards,
Bruno
stamufa likes this.
Old   June 9, 2010, 12:10
Thank you for your reply, Bruno
I am still having the same problem. The solver - chtMultiRegionHeater - runs, but when I try to view the volume fields in ParaView they disappear after the initial time.
Old   June 9, 2010, 15:54
I figured it out. Hooray.
Old   June 10, 2010, 06:07
toto
ronaldo is on a distinguished road
use foamTovtk to view the result
ronaldo is offline   Reply With Quote
Old   June 11, 2010, 05:35
Cyp
Cyprien
Cyp is on a distinguished road
I have the same problem that m.nichols19. I use OpenFOAM 1.6 and I don't have the foamTovtk application. Is it normal ?
Cyp is offline   Reply With Quote
Old   June 11, 2010, 18:18
Bruno Santos
Greetings Cyp,
The correct name is foamToVTK. Linux is case sensitive by default, so if you miss just one character's case, it's an invalid command
As for not seeing the fields:
  1. can you see the fields in the cavity tutorial? You know, the first one from the user guide?
  2. how are you running the chtMultiRegionFoam case tutorial? Are you using the Allrun inside the case folder script? Does it create 5 files with the named regions and do they end with ".OpenFOAM"?
If the answer is no for the first point, then follow the instructions from this post: ParaView Stopped Working post #4
Best regards,
Bruno
Old   June 12, 2010, 05:55
Cyp
Cyprien
Hi wyldckat, thank you for your answer.
Indeed, I have the foamToVTK application. When I run it,
cyp@cyp-laptop:~/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater$ foamToVTK
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 1.6-f802ff2d6c5a
Exec   : foamToVTK
Date   : Jun 12 2010
Time   : 10:43:46
Host   : cyp-laptop
PID    : 1766
Case   : /home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Deleting old VTK files in "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK"
Time: 0
    volScalarFields            : K rho p cp k T epsilon
    volVectorFields            : U
    Internal  : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/multiRegionHeater_0.vtk"
    Original cells:3000 points:3751   Additional cells:0  additional points:0
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxY/maxY_0.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minX/minX_0.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxX/maxX_0.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minY/minY_0.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minZ/minZ_0.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxZ/maxZ_0.vtk"
Time: 0.001
    Internal  : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/multiRegionHeater_1.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxY/maxY_1.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minX/minX_1.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxX/maxX_1.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minY/minY_1.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minZ/minZ_1.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxZ/maxZ_1.vtk"
Time: 50.001
    Internal  : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/multiRegionHeater_2176.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxY/maxY_2176.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minX/minX_2176.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxX/maxX_2176.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minY/minY_2176.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minZ/minZ_2176.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxZ/maxZ_2176.vtk"
Time: 100.001
    Internal  : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/multiRegionHeater_4417.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxY/maxY_4417.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minX/minX_4417.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxX/maxX_4417.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minY/minY_4417.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minZ/minZ_4417.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxZ/maxZ_4417.vtk"
Time: 150.001
    Internal  : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/multiRegionHeater_6591.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxY/maxY_6591.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minX/minX_6591.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxX/maxX_6591.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minY/minY_6591.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minZ/minZ_6591.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxZ/maxZ_6591.vtk"
Time: 200.001
    Internal  : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/multiRegionHeater_8719.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxY/maxY_8719.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minX/minX_8719.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxX/maxX_8719.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minY/minY_8719.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/minZ/minZ_8719.vtk"
    Patch     : "/home/cyp/OpenFOAM/cyp-1.6/run/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/VTK/maxZ/maxZ_8719.vtk"
End
That seems ok. However, then, when I attempt to see my field with paraFoam, as previously, nothing more happens...
paraFoam successfully runs the cavity tutorial case and I have the 5 files you mentioned above:
multiRegionHeater{bottomAir}.OpenFOAM
multiRegionHeater{heater}.OpenFOAM
multiRegionHeater{leftSolid}.OpenFOAM
multiRegionHeater{rightSolid}.OpenFOAM
multiRegionHeater{topAir}.OpenFOAM
I also noticed that my paraFoam shut down with the following message :
QPainter::begin: Paint device returned engine == 0, type: 2
FOAM exiting
Regards,
Cyp
PS : I execute the Allrun script
Old   September 9, 2010, 10:31
Default Vtk
marval is on a distinguished road
Hi, everyone!
I don't find the VTK folder in chtMultiRegionSimpleFoam but I do find it in chtMultiRegionFoam. Can I copy this one to the other one? Or is there a huge difference between the two?
Regards
Marco
marval is offline   Reply With Quote
Old   September 9, 2010, 12:14
I will need a few more details before I can answer your question, marval. Does running foamToVTK not create the VTK directory in your chtMultiRegionSimpleFoam case directory? Did you run the same case using both chtMultiRegionFoam and chtMultiRegionSimpleFoam?
Old   September 9, 2010, 12:21
Hmmm, I really don't know how this works but when I use the Allrun script the VTK folder appears.
It doesn't look that I need to use foamToVTK to view my results, do the Allrun script do it? Because I don't see anything in the script though.
I hope I'm not too confusing.
Regards
Marco
Old   September 9, 2010, 12:56
The VTK directory created by the Allrun script is irrelevant. You will need to run
foamToVTK -region
for each region.
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 12:42
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 04:25
Watching the chtMultiRegionFoam tutorial in Paraview anke OpenFOAM 1 March 1, 2010 09:38
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 10:41
