Understanding fvm::Sp()
Like Tree35Likes
  • 1 Post By Hyu
  • 34 Post By Simon Lapointe
Old   May 22, 2010, 07:17
Default Understanding fvm::Sp()
Hyu
Hyu is on a distinguished road
I was reading the code for the LaunderSharmaKE model (incompressible), then I ran into this:
  tmp<fvScalarMatrix> epsEqn
        fvm::ddt(epsilonTilda_)
      + fvm::div(phi_, epsilonTilda_)
      - fvm::laplacian(DepsilonEff(), epsilonTilda_)
        C1_*G*epsilonTilda_/k_
      - fvm::Sp(C2_*f2()*epsilonTilda_/k_, epsilonTilda_)
      + E
I have a question: Why is one term represented with fvm::Sp() and the others (though pretty similar) are not?
Kummi likes this.
Hyu is offline   Reply With Quote
Old   May 22, 2010, 07:43
Simon Lapointe
Simon Lapointe is on a distinguished road
fvm::Sp makes the source term implicit so it contributes to the diagonal. This can help convergence when the source term is negative on the rhs (sink term). This is the case in the equation you've shown.
The two other source terms are positive on the rhs and therefore left explicit. Making them implicit would reduce the diagonal dominance of the matrix and probably cause problems to the solver.
Hope this helps
Elham, Bufacchi, D.R. and 31 others like this.
Simon Lapointe is offline   Reply With Quote
Old   May 22, 2010, 09:38
Hyu
Thank you for your fast and complete answer. That is wat I wanted to know.
Old   May 26, 2010, 10:21
Costas K
thekay is on a distinguished road
Send a message via ICQ to thekay Send a message via MSN to thekay
On the basis of the above explanation, is it advised to have the pressure on the right hand side of the equation to solve, in an expression that is treated implicitly, or the opposite? For instance the hEqn.H of buoyantSimpleFoam, has pressure under fvc:
fvm::div(phi, h)
      - fvm::Sp(fvc::div(phi), h)
      - fvm::laplacian(turbulence->alphaEff(), h)
        fvc::div(phi/fvc::interpolate(rho)*fvc::interpolate(p))
      - p*fvc::div(phi/fvc::interpolate(rho))
thekay is offline   Reply With Quote
Old   February 9, 2016, 13:44
Default Question about the source term
Saurabh Tandon
STutexas is on a distinguished road
Hi
I have another question about the fvm::Sp() term in the equation. If you this source term in any equation:
fvm::Sp(C2, u), where u is velocity, can C2 be a tensor or a tensor field?
If not, can anyone suggest how to code an-isotropic, hetorgeneous term in the equation.
Thank you.
STutexas is offline   Reply With Quote
Old   July 26, 2016, 00:11
Default I am having the same problem
Mateus Palharini Schwalbert
mateusps is on a distinguished road
I have the same doubt as STutexas: how to code an anisotropic, heterogeneous term in the source term in the momentum equation.
I see the fvm::Sp(tensor,vector) does not work. I took a look at the porousSimpleFoam code, which does this in adding the porous resistance term. But porousSimpleFoam code deals with this in a different manner, through adding an addResistance function, which I don't quite understand (I'm new here).
Any ideas on how to code an anisotropic, heterogeneous term in the source term in the momentum equation?
Did you solve this problem, STutexas?
mateusps is offline   Reply With Quote
Old   July 26, 2016, 02:09
Saurabh Tandon
Hi Mateus
It seems that fvm::Sp() can only take in vectors and not tensors. Defining a tensor does not work .
I tried the following approach: Use fvc::Sp() and define your term as constant source term in the RHS of the vector equation. Then iterate over the equation several times until the values converge.
I hope it helps. Let me know if you come up with another method to solve this.
Thank you.
Problem understanding rhoPisoFoam MatP OpenFOAM Running, Solving & CFD 1 May 15, 2010 14:21
Help using an understanding y+ siw CFX 4 October 4, 2009 11:23
Understanding of channelOodles and oodles solver fs82 OpenFOAM 1 September 23, 2009 11:36
understanding dual-time stepping srinath Main CFD Forum 1 August 11, 2008 12:05
Help understanding Memory Allocation Factor Todd CFX 1 March 6, 2008 14:27
