May 21, 2010, 06:43 |
Searching for a multispecies solver with buoyant dispersion
Rep Power: 16 |
I want to simulate the injection of helium into air in a garage, at constant temperature. I used the reactingFoam solver adding the gravity effect (rho*g) in the UEqn. The point is that I can't see any buoyancy effects on my results : HE and air are mixing like if there was no difference of density effect between species and I don't understand why... This effect is very important for my simulation because after a while the injection is turned down in order to observe the dispersion of helium. Have I to modify the scalar transport equation? Is an other solver better for my case? I've seen another way using alpha, like in the twoLiquidMixingFoam solver, but I don't know if I can adapt it to my simulation because even if I have two species to transport, I have only one phase. Thank you in advance for your answers ! Pierre Last edited by Pierre Mathieu; May 21, 2010 at 12:34. |
May 26, 2010, 05:21 |
Rep Power: 16 |
If some of you is interested in my case, I think I found my problem : reactingFoam resolves U equation with a constant density, so doesn't take into account variation of density in the flow due to mixing of species. To solve this problem I am now running twoLiquidMixingFoam solver which calculates changes in density and return it to the velocity equation so that the changes of density impact on the flow. I hope better results with this solver ! |
May 26, 2010, 09:07 |
Thank you for the update Pierre. Are your new results better?
May 27, 2010, 04:38 |
Rep Power: 16 |
Hi Thekay,
No there not, and I don't understand why... I obtained quite the same results with both solvers. |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
multi species modelling | uitm | Siemens | 2 | April 24, 2010 09:10 |
Problem with buoyant solver | dasch | OpenFOAM Running, Solving & CFD | 0 | April 20, 2010 04:41 |
HELP: User subroutines for multi species system | sherry | Siemens | 0 | October 8, 2004 12:08 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
