liftDrag
Like Tree7Likes
  • 1 Post By rflats
  • 2 Post By rflats
  • 1 Post By matdgonz
  • 1 Post By davemanson
  • 1 Post By rflats
  • 1 Post By ssmeherk
Old   May 20, 2010, 03:07
Default liftDrag
karthik
karthik_be is on a distinguished road
Hi to everyone,
I'm quite new to OpenFOAM, for the past 6 months I'm working on NACA4412 project, thing were fine till my case was under Incompressible flow. But as i took Compressible flow the problem started to encounter into my case....
Please i need some help with this regard..
Particulars
Case : NACA4412
Software: OpenFoam
flow solver : sonicFoam
Turbulence model : Std k-epsilon model
Query : I'm not getting liftdrag coeff... I heard through somebody that for sonicFoam lift & drag cant be calculated... Plz help me in this regard... Waiting for the reply..
karthik_be is offline   Reply With Quote
Old   May 21, 2010, 09:22
Ngoc-Minh Truong
truong_nm is on a distinguished road
Send a message via MSN to truong_nm
Add these lines at the end of your controlDict file:
functions
forces
type forceCoeffs;
functionObjectLibs ( "libforces.so" );
outputControl timeStep;
outputInterval 1;
patches
EXTRADOS INTRADOS
pName p;
UName U;
log true;
rhoInf 1.1768292;
CofR ( 0 0 0 );
liftDir ( -0.04483992 0 0.99899418 );
dragDir ( 0.99899418 0 0.04483992 );
pitchAxis ( 0 1 0 );
magUInf 208.312257;
lRef .61;
Aref .61;
And change the values of course
truong_nm is offline   Reply With Quote
Old   May 24, 2010, 06:36
Default liftDrag
karthik
Thanks for such an wonderful response Mr. Ngoc-Minh Truong,
sorry, I've not mention...
Particulars
Case : NACA4412
Software: OpenFoam 1.4.1
Old   July 5, 2010, 21:25
Jie
jiejie is on a distinguished road
lRef .61;
Aref .61;
Hi truong_nm
Can I just ask what is IRef and Aref and what sort of values should we use?
Thanks
jiejie is offline   Reply With Quote
Old   July 6, 2010, 08:41
Ricardo Flatschart
rflats is on a distinguished road
Originally Posted by jiejie View Post
Hi truong_nm
Thanks
Hi Jie,
lRef and ARef are the reference length and area, respectively. This information is necessary for calculating the lift and drag coefficients.
If you are working with a 2D airfoil, you need to specify the chord of the airfoil as reference length and reference area.
Mike_star likes this.
rflats is offline   Reply With Quote
Old   July 6, 2010, 09:12
Jie
Originally Posted by rflats View Post
Hi Jie,
Thank you for your reply truong_nm
I got some quick questions as follows:
1. If we look at 2D cases:
For a 2D aerofoil with chord length of 1, can we assume the area is 1 as well or it is better to calculate it?
For a 2D cylinder flow, lRef = diameter of the cylinder and ARef is the area of the cylinder?
2. If we look at 3D cases:
Will lRef and ARef same as the 2D cases?
Old   July 6, 2010, 09:56
Ricardo Flatschart
Answering your questions:
1. For a 2D airfoil, you can simply put Aref=lRef=chord length.
In the case of a 2D cylinder, Aref=lRef=diameter
2. For 3D cases, you have to put reference dimensions that are compatible with your problem. For instance, if you are studying a 3D wing, it makes sense to put lRef equal to the mean aerodynamic chord of the wing, and Aref as the planform area of the wing.
Old   July 6, 2010, 20:46
Jie
Hi Rflats
For a 2D cylinder case, why whould Aref = diameter?
For 3D aerofoil, the planform area = spanwise area (projected aera from top view)?
Thank you
Old   July 7, 2010, 04:46
Ngoc-Minh Truong
For a cylinder, it would be PI/4 * diamater * diameter otherwise it is not a surface. No ?
Old   July 7, 2010, 04:48
Jie
That's what I am thinking, or it is the projected surface from top view?
Old   July 7, 2010, 12:01
Ricardo Flatschart
When calculating the drag coefficient, one has to choose what are the geometrical parameters that make sense for each particular case. In the case of 3D bluff bodies (e.g. a passenger car, or a sphere), the drag is related mainly to the transversal dimensions w.r.t. the flow. So, for a car, normally one use the maximum cross sectional area as a reference area. For a sphere, normally one uses pi*r^2 (note that it is not the surface area 4*pi*r^2). For streamlined 3D bodies, the drag is mainly governed by skin friction, so it makes sense using the surface area as reference area. In the particular case of wings, the planform area is not so different of the wing surface area, so it is used in the adimensionalization. For 2D bodies, the same ideas apply. So, for a 2D cylinder you can use the diameter as a reference "area". For profiles, you can use the chord length as a reference "area"
Old   July 7, 2010, 20:55
Jie
Hi rflats Thanks for your explanation
I think I got your point, it is the planform area governs the drag and lift coefficients in both 2D and 3D cases. Hence, Aref = diameter for 2D cylinder as there is not spanwise length, and Aref = diameter x spanwise length for 3D cylinder case. Am I right?
Old   September 13, 2010, 12:48
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
So for an airfoil with a chord of 1.0 and a span of 0.5 you would set
lRef = 1.0
Aref = 0.5
right? It would make sense since the lift and drag forces need the area and the corresponding coefficients require the chord length (for airfoils).
/Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   October 7, 2010, 07:28
Vesselin Krastev
vkrastev is on a distinguished road
Hi Rflats,
I'm sorry for posing another time such a trivial question, but I'm trying to calculate the drag coefficient for a flow on a 2D cylinder and, following your suggestion of setting Aref=lref=cylinder diameter, my preliminar esults are completely wrong...
The testcase which I'm referring to is a very low Re case (Re=33), and I'm using the pimpleFoam transient solver (OpenFOAM 1.6) with turbulence switched off. The solution converges well, but the drag coefficient printed by the forceCoeffs goes to about 0.1, when the effective drag coefficient at this Re number should be of about 1.5. Here I post some additional information about the case in question
Cylinder diameter = 1m
Free stream velocity magnitude = 1m/s
Kinematic viscosity = 0.03 m^2/s
controlDict setting:
application pimpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 10;
deltaT 0.002;
writeControl adjustableRunTime;
writeInterval 0.2;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep no;
maxCo 0.8;
functions
// forces
// type forces;
// functionObjectLibs ("libforces.so"); //Lib to load
// patches (ala); // change to your patch name
// rhoName rhoInf;
// rhoInf 1.184; //Reference density for fluid
// CofR (1 0 0); //Origin for moment calculations
// outputControl timeStep;
// outputInterval 1;
forceCoeffs
// rhoInf - reference density
// CofR - Centre of rotation
// dragDir - Direction of drag coefficient
// liftDir - Direction of lift coefficient
// pitchAxis - Pitching moment axis
// magUinf - free stream velocity magnitude
// lRef - reference length
// Aref - reference area
type forceCoeffs;
patches (cylinder);
rhoName rhoInf;
rhoInf 1.184;
CofR (0.1 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 1);
magUInf 1;
lRef 1;
Aref 1;
outputInterval 50;
Any help or suggestions would be really appreciated...
Thank you in advance
V.
vkrastev is offline   Reply With Quote
Old   October 7, 2010, 09:32
Ricardo Flatschart
Hi Vesselin,
This occurs because OpenFOAM is not a "pure" 2D solver. In fact, it always uses 3D meshes, and the 2D simulation is made by a special treatment of the boundary conditions in the spanwise direction.
So, in a purely 2D solver, my statement is correct. But, if using OpenFoam, you have to set Aref as (cylinder diameter)*(length in the spanwise direction).
Sorry for the confusion...
Regards,
Ricardo
stainboy and random_ran like this.
Old   October 7, 2010, 10:59
Vesselin Krastev
Hi Vesselin,
Regards,
Ricardo
Hi Ricardo,
thanks for the clarification: I've changed the settings in my controlDict and now all seems to work properly.
Regards
V.
Old   February 17, 2013, 13:33
Default Drag coef of cylinder
  #17
Matt
matdgonz is on a distinguished road
hi, quite new to openfoam, im using pisoFoam, k-e turbulence model, Re=10,000. However, i get a Cd of around 0.9 instead of somthin higher aroudn 1.4 (according to book)
I was reading the above threads regarding the drag coefficient of a cylinder.
this is my controlDic;
application pisoFoam;
startTime 0;
stopAt endTime;
endTime 600;
deltaT 1;
writeControl timeStep;
writeInterval 10;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
functions
forces
type forces;
patches (cylinder); // change to your patch name
rhoName rhoInf;
rhoInf 1.1614; //Reference density for fluid
CofR (-0.5 0 0); //Origin for moment calculations
outputInterval 1;
forceCoeffs
type forceCoeffs;
patches (cylinder);
rhoName rhoInf;
rhoInf 1.1614;
CofR (-0.5 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 1);
magUInf 0.1;
lRef 1; //
Aref 1; //
outputInterval 1;
As such i don't think it could be wrong values within the ControDic file.
Should i increase the Mesh close to the cylinder? That should give a much btr result or would it just be more accurate around 0.9?
xerxes92005 likes this.
matdgonz is offline   Reply With Quote
Old   February 21, 2013, 19:49
dave
davemanson is on a distinguished road
I am just curious as to how to actually get realistic values of lift and drag coefficients using this script added into my controlDict for a 2D airfoil. The airfoil points in my geometry suggest that the Lref would be 1 and hence so would the Aref, however my coeff of lift and drag are around 10^-8 etc.
To try and correct this I changed my RhoInf from 1000 to 1.184 as it was a mistake. and also changed Lref and Aref to 0.001 as I noticed in the blockmesh it seems to convert interpret the input values in mm. Does anyone know if I am doing anything severely wrong?
Thank you,
Dave
| \\ / O peration | Version: 1.7.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 1000;
deltaT 1;
writeInterval 50;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
functions
totalDrag
type forceCoeffs;
patches (airfoil);
rhoName rhoInf;
rhoInf 1.184;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 1);
magUInf 50;
lRef 0.001;
Aref 0.001;
outputInterval 5;
davemanson is offline   Reply With Quote
Old   February 21, 2013, 20:15
Ricardo Flatschart
Please try setting the reference area as Aref=(airfoil chord length)*(length in the spanwise direction of your 2D domain). See the postings above for the explanation.
Cheers,
Ricardo
Old   February 7, 2014, 08:53
Post
  #20
Meher
ssmeherk is on a distinguished road
I am having a set of benchmark results for 2D case of flow over cylinder and am trying to match my Cd and Cl values with the benchmarked ones but in vain. I am getting an error of 14% which is clearly unacceptable.
On what basis one should decide the length of span-wise direction in case of 2D flow around a cylinder ? I opened the geometry in ParaFoam and checked the z-direction length and supplied the same value as input for length of span-wise direction.
Please help me where I am doing wrong.
Thanks in advance,
Meher.
ssmeherk is offline   Reply With Quote
Question to liftDrag hoochie OpenFOAM Post-Processing 29 September 19, 2014 04:38
Adding liftDrag to Openfoam141 srinath OpenFOAM Running, Solving & CFD 9 August 25, 2009 14:39
LiftDrag for 141 ryan_m OpenFOAM Running, Solving & CFD 2 August 24, 2009 22:26
LiftDrag compiling problem vdb OpenFOAM Pre-Processing 2 June 16, 2008 10:45
Compiling liftDrag crashed with initc%3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumclipartsadgif%22 ALT%3d%22%22 BORDER%3d0%3etext0x20 undefined reference to %60mainb sponiar OpenFOAM Running, Solving & CFD 2 January 17, 2008 05:00
