Pipe flow using Simple Foam
Like Tree1Likes
  • 1 Post By wildfire230
Old   May 14, 2010, 08:47
Default Pipe flow using Simple Foam
sam
sameer_kumar is on a distinguished road
Dear All,
I am comparing pipe flow simulation between CFX and Openfoam (using simplefoam solver) with different boundary conditions.
Boundary condition1: Velocity inlet - 1 m/sec
Pressure outlet - 0
Boundary condition 2: Pressure inlet : 497925.3 m2/s2
Pressure outlet : 489626.6 m2/s2
The comparison of pressure contour and velocity contour files are attached.
The values of presssure and velocities from CFX and Openfoam are not matching at all.
Can please let me know the where I am doing mistake in Openfoam.
Regards,
Sam
sameer_kumar is offline   Reply With Quote
Old   May 14, 2010, 08:56
sam
Pressure contours and velocity contour for boundary conditions 2
Old   June 22, 2010, 09:51
Vitor Braga
vitor is on a distinguished road
Sameer,
I'm also trying to perform a pipe flow using simpleFoam and compare it with Fluent. I'm still setting up my OpenFOAM case,so could you share your cases with me? I mean, initial and boundary conditions (the 0 directory, including turbulence initialisation), your control dictionary and your transport properties?
Then if I get any results, I'll let you know.
Thank you.
BR,
Vitor Braga
vitor is offline   Reply With Quote
Old   June 29, 2010, 09:37
Default openfoam-fluent
beauty
beauty is on a distinguished road
Vitor Braga,
what is your result? Looking forward for your results!
Thanks
beauty
beauty is offline   Reply With Quote
Old   June 29, 2010, 09:48
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Turbulent or laminar flow? Air or water? Are you using the same mesh? Are you modelling it using wedge boundaries in openfoam? You need to be clearer about what you're modelling; looking at your ANSYS velocity plot, it looks more like a turbulent profile than laminar, what's the Reynolds number?
If it's a laminar flow, the result is very sensitive to the mesh refinement.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   August 27, 2013, 13:01
wildfire230 is on a distinguished road
Hi, I know this is an old post, but why is the result very sensitive to the mesh refinement for laminar pipe flow? Could you please explain it to me? Thanks
rbaud likes this.
wildfire230 is offline   Reply With Quote
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 15:28
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
simple pipe flow question arkur CFX 1 July 11, 2008 17:32
Pressure Drop - Please Help - Simple Pipe Flow Joe A. FLUENT 2 April 23, 2007 08:50
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
