cyclic boundary condition doesn't work in a tube ??
Like Tree1Likes
  • 1 Post By David_010
Old   April 15, 2010, 09:51
Default cyclic boundary condition doesn't work in a tube ??
Cyp
Cyprien
Cyp is on a distinguished road
Hi !
I try to simulate a flow through a tube (2D) with cyclic boundary condition at the inlet and the outlet.
A poiseuille's flow profile (parabolic) is expected along the tube. However, it works only after a distance from the inlet. I belevied that with the cyclic condition, I will get the same profile all along the tube. Why does my simulation is like that ??
I obtain exactly the same profile when I define my inlet and outlet as "patch".
My initial conditions are :
p :
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
U :
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform (4 0 0);
thank you for your help,
Cyp
Cyp is offline   Reply With Quote
Old   April 15, 2010, 09:55
David
David_010 is on a distinguished road
Can you put here the cyclic condition you have used?
David
David_010 is offline   Reply With Quote
Old   April 15, 2010, 10:05
Cyp
Cyprien
In my blockMeshDict I defined :
patches
cyclic inlet
(0 4 7 3)
cyclic outlet
(1 5 6 2)
wall fixedWalls
(3 7 6 2)
(1 5 4 0)
empty frontAndBack
(0 3 2 1)
(4 5 6 7)
It is the question you asked me ?
Old   April 15, 2010, 12:00
Cyp
Cyprien
Indeed, I haven't well defined my cyclic condition.
It works now when I defined inout instead of inlet and outlet patches.
cyclic inout
(0 4 7 3)
(1 5 6 2)
For my pressure initial condition, I used
inout
type fan;
patchType cyclic;
f List<scalar> 1(-5.00); // p_OF = p_real / rho
value uniform 0;
Is it the single manner to do ?
Old   April 15, 2010, 13:11
David
Yes it is the correct manner. You can also use de b.c directMapped, which takes the outlet velocity and recicles it to the inlet patch.
David
Old   April 15, 2010, 15:11
Cyp
Cyprien
I improved my case considering two-phase flow. I use the interFoam solver.
I patch well my region.
When I launch the interFoam solver, I get this error message :
Unable to set reference cell for field p
    Please supply either pRefCell or pRefPoint
file: /home/cyp/OpenFOAM/cyp-1.6/run/test07/system/fvSolution::PISO from line 55 to line 60.
    From function void Foam::setRefCell
    const volScalarField&,
    const dictionary&,
    label& scalar&,
    bool
    in file cfdTools/general/findRefCell/findRefCell.C at line 112.
FOAM exiting
Do you know what does it mean and what's wrong in my case ??
Old   April 16, 2010, 16:21
David
I don't know what is the problem. When you tried the cyclic condition and it worked, was whit this solver? If not, perhaps this solver doesn't work with the cyclic condition and this b.c for pressure. But I'm just guessing. I suppose you want to fix the mass flux? if not, you can set only:
inout
type cyclic;
value uniform 0;
for pressure. And fix the velocity in the "boundary field" (0/U). If it still doesn't work...I don't know. But may be the directMapped condition is a good alternative.
Sorry for my poor help
David
mohammad81 likes this.
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 06:05
Cyclic Boundary Condition SG Siemens 0 June 1, 2008 15:56
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
About Partial Cyclic Boundary Condition Jiaying Xu Siemens 2 October 31, 2002 21:12
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 17:53
