Henry's law as boundary condition at an liquid/gas interface
Like Tree1Likes
  • 1 Post By Cyp
Old   April 13, 2010, 10:17
Default Henry's law as boundary condition at an liquid/gas interface
Cyp
Cyprien
Cyp is on a distinguished road
hi everybody,
I need to apply Henry's law (Cl=H*Cg) at the interface between liquid and gas phases.
In the documentation it is said that the primitive types "calculated" is for "boundary field phi derived from other fields". Is it this type I have to use ? How does it work ??
Thank you for your help,
Cyprien
wayne14 likes this.
Cyp is offline   Reply With Quote
Old   April 18, 2010, 18:40
Cyp
Cyprien
Hi !
Anybody can advise me ??
In fact, I would like to add 2 transport scalar equations in the interFoam solver (for Cg and Cl). These concentrations are linked at the interface by Henry's law (Cg=H*Cl) and the equality of the flux.
I know how to add the 2 equations, but I have no idea about the BC treatment at the interface......
Old   April 19, 2010, 03:06
Holger Marschall
holger_marschall is on a distinguished road
Send a message via Skype™ to holger_marschall
Hi Cyp,
this is not possible, since interFoam is based upon a so called immersed interface concept, meaning that the the interface between different immiscible fluids is embedded or immersed into the interior of the computational domain rather than aligning it to the computational grid boundaries.
So you either need a model which mimics the boundary condition at the interface or you should use interTrackFoam which is a free surface deforming mesh solver, developed at FSB Zagreb by dr. Zeljko Tukovic that would allow a b.c. to be imposed at the interface
(http://openfoamwiki.net/index.php/Co...interTrackFoam).
Hope that helps,
Holger Marschall
web: http://www.holger-marschall.info
mail: holgermarschall@yahoo.de
holger_marschall is offline   Reply With Quote
Old   April 19, 2010, 05:39
Cyp
Cyprien
Hi Holger !
Thank you for your answer. I had a look on your link. It seems good for me.
However, in my problem, I consider a fixed interface. So, I can uncouple the hydrodynamic and the mass transfer.
It is ok for the hydrodynamic (moreover, I have an analytical solution for the velocity profile).
For the mass transfer, how could the BC be imposed at the fixed "interface" ? I haven't found any docs about that...*
Cyp
Old   April 19, 2010, 06:00
Holger Marschall
in this case have a look at solvers with multi-domain support (i.e. for conjugate heat transfer). These should provide all functionality you need.
A few links to start from:
- http://www.cfd-online.com/Forums/ope...-openfoam.html
- http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008/chtFoam.pdf
- http://www.csi.tu-darmstadt.de/media...ledsystems.pdf
Hope that helps.
best,
Holger Marschall
Old   April 22, 2018, 17:27
Peng Liang
tjliang is on a distinguished road
Originally Posted by holger_marschall View Post
Hope that helps.
best,
Dear Holger Marschall,
I have a similar problem, I need to simulate plasma flow over water. And the particles generated inside plasma diffuse into water by Henry‘s law. Could you please tell me which solver might be a best choice for me to start? I previously use Chtmultiregionfoam but this solver only handles fluid-solid interaction but never fluid-fluid.
Thanks in advance,
Peng
tjliang is offline   Reply With Quote
Old   April 23, 2018, 05:11
Cyp
Cyprien
Hi Peng,
please have look at these threads:
Equilibrium thru Interface
InterFoam: Add an equation to only one phase
Cheers,
Cyprien
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
interface boundary condition shanth reddy Main CFD Forum 0 April 14, 2005 06:56
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 11:06
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 17:53
boundary condition @ interface Steve Main CFD Forum 4 August 3, 2001 13:36
