Test cases for rhoSimpleFoam & sonicDyMFoam
Like Tree4Likes
  • 2 Post By askjak
  • 2 Post By RalphS
Old   April 6, 2010, 06:06
Default Test cases for rhoSimpleFoam & sonicDyMFoam
Andrey
sim1246 is on a distinguished road
I am new user of OpenFOAM-1.6. I can't find test for rhoSimpleFoam & sonicDyMFoam. Where I can find them?
Thanks in advance
sim1246 is offline   Reply With Quote
Old   April 6, 2010, 11:01
Default rhoSimpleFoam tutorial case
askjak is on a distinguished road
Hey,
I have compiled a test case.
-Ask
Technoyoungman and kornickel like this.
askjak is offline   Reply With Quote
Old   April 7, 2010, 01:37
Andrey
Originally Posted by askjak View Post
Hey,
-Ask
Thank you very much!!!
Old   October 27, 2010, 19:04
Default help with rhosimplefoam tutorial
Kevin Hoopes
khoopes is on a distinguished road
So I cannot get this tutorial to run, I ran blockmesh and thenn rhosimplefoam and I get this
-bash-3.2$ rhoSimpleFoam
| \\ / O peration | Version: 1.7.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.0-5773603db906
Exec : rhoSimpleFoam
Date : Oct 27 2010
Time : 16:03:34
Host : m6int01.fsl.byu.edu
PID : 31220
Case : /bluescr/khoopes/sims/angledDuct
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
Reading field U
--> FOAM FATAL IO ERROR:
keyword rhoMax is undefined in dictionary "/bluescr/khoopes/sims/angledDuct/system/fvSolution::SIMPLE"
file: /bluescr/khoopes/sims/angledDuct/system/fvSolution::SIMPLE from line 70 to line 71.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 395.
FOAM exiting
khoopes is offline   Reply With Quote
Old   October 28, 2010, 04:16
RalphS is on a distinguished road
Since OpenFOAM 1.7 you have to define rhoMax and rhoMin like you define pMin. Here is an example:
SIMPLE
nUCorrectors 2;
nNonOrthogonalCorrectors 0;
pMin pMin [1 -1 -2 0 0 0 0] 1000;
rhoMax rhoMax [1 -3 0 0 0] 2;
rhoMin rhoMin [1 -3 0 0 0] 0.001;
RalphS is offline   Reply With Quote
Old   October 28, 2010, 18:52
Kevin Hoopes
That worked great for that tutorial, thanks for the quick reply. I have used your case as a model for my geometry, and now I am getting this error.
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 5914.4
Specified mass inflow : 30.8438
Specified mass outflow : 30.8437
Adjustable mass outflow : 0
Any Ideas? I have tried running potentialFoam, but it has the same problem. I have used your U boundry condition on the inlet, and also tried just a fixed value with similar results.
Thanks,
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Test cases of different levels of complexity quarkz Main CFD Forum 1 September 15, 2005 19:47
test cases Maciej Matyka Main CFD Forum 3 November 24, 2004 09:27
Standard CFD test cases? Damon Qualski Main CFD Forum 1 April 10, 2003 15:10
