Nonlinear k epsilon Shih Model
Like Tree2Likes
  • 1 Post By Moelfus
  • 1 Post By Moelfus
Old   February 25, 2010, 11:16
Default Nonlinear k epsilon Shih Model
Claus Meister
idrama is on a distinguished road
Hallo Foamers!
Does anybody know a reference where I can find the derivation of the Nonlinear k e Shih model?
Cheers
idrama is offline   Reply With Quote
Old   May 21, 2010, 03:39
Claus Meister
Does really nobody knows a reference, at least one? HELP
Old   May 21, 2010, 04:05
Claus Meister
Old   August 24, 2010, 04:28
Olli
Moelfus is on a distinguished road
Hi Claus,
the paper you are searching for can be found at the NASA pages. There you have access to a lot of other papers of Shih:
http://ntrs.nasa.gov/search.jsp?R=35...%257c1%26N%3D0
Best regards,
Olli
aow likes this.
Moelfus is offline   Reply With Quote
Old   August 25, 2010, 10:29
Thomas Baumann is on a distinguished road
have you simulated successful using this turbulence-model?
I have problems near walls (U isn't zero orthogonal to the wall in the nearwall-part even in channel-flows).
Regards Thomas
Thomas Baumann is offline   Reply With Quote
Old   August 26, 2010, 05:29
Olli
yes I'm using this turbulence model for simulating swirling flows. For this purpose it seems to be perfect. I haven't discovered any problems until know.
Olli
fumiya likes this.
Old   August 26, 2010, 06:11
I have velocities out of the wall.
I have described this in a posting here in the forum.
http://www.cfd-online.com/Forums/ope...inearshih.html
But if I'm using a very fine mesh (y+ < 0.4) the results are better. So the solution has a mesh-dependence.
Maybe it's caused by the fvschemss are the solvers for p,U,k...
I have tried different ones without success.
Could you maybe show your fvschemes and the fvSolution-data, please?
Thanks and regards,
Thomas
Old   August 27, 2010, 07:32
Olli
Hi Thomas,
a y+ of less than 0.4 seems to be a sufficient fine mesh. Nevertheless, are k-epsilon models known for their bad boundary layer behaviour. Therefore this model uses an boundary layer model in the near wall region. I can look up how it is set up. If the results have a mesh-dependence you should probably do a grid study :-( An other way would be to use an much coarser mesh, if boundary layers are not prior-ranking.
Olli
fvSchemes:
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
// grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) Gauss linearUpwindV Gauss linear;
div(phi,k) Gauss upwind;
div(phi,omega) Gauss upwind;
div((nuEff*dev(grad(U).T()))) Gauss linear;
div(nonlinearStress) Gauss linear;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) Gauss upwind;
laplacianSchemes
default Gauss linear corrected;
// default Gauss linear limited 0.5;
// default Gauss linear limited 0.333;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
fvSolution:
solvers
p
solver GAMG;
preconditioner FDIC;
mergeLevels 1;
smoother GaussSeidel;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 100;
tolerance 1e-06;
relTol 0.01;
U
solver GAMG;
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
mergeLevels 1;
tolerance 1e-05;
relTol 0;
k
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
epsilon
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
R
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
nuTilda
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
relaxationFactors
p 0.2;
U 0.5;
k 0.7;
epsilon 0.7;
R 0.7;
nuTilda 0.7;
Old   August 27, 2010, 12:05
thank you very much.
I have simulated using your given condition, but the velocities didn't get better.
Have you ever simulated a non-swirling flow using this model?
Regards Thomas
Old   August 30, 2010, 10:37
Olli
no, I never simulated a non-swirling case with this model. I just used the model because all other models either crashed or over predicted the axial velocity. I looked at your other post and really have no idea what is going wrong there.
Olli
Old   March 12, 2018, 14:35
Default Update for link to Shih et al. 1993
  #11
aow
Andrew O. Winter
aow is on a distinguished road
Hey all, I tried Moelfus' link to the paper, but it looks as if NASA changed it since it could not be found at that address. The correct one is now...
https://ntrs.nasa.gov/archive/nasa/c...9930007407.pdf.
aow is offline   Reply With Quote
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 16:25
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 21:51
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 05:19
K-Epsilon Model sangit Main CFD Forum 2 September 9, 2004 14:19
