Periodic B.C or Inlet/Outlet B.C
Like Tree7Likes
  • 1 Post By ar_mofidi
  • 5 Post By wenterodt
  • 1 Post By Thomas Baumann
Old   February 24, 2010, 08:41
Question Periodic B.C or Inlet/Outlet B.C
alireza
ar_mofidi is on a distinguished road
Hi guys
I want to know that, how can I use icoFoam for the laminar microchannel and which of the boundary condition need to use, periodic or inlet/outlet.
Thanks,
Luttappy likes this.
ar_mofidi is offline   Reply With Quote
Old   February 25, 2010, 02:19
Tammo Wenterodt
wenterodt is on a distinguished road
If you want to simulate a fully developed channel flow in constant cross sections or in a periodically repeating geometry, the cyclic boundary condition for the U-field is what you need. The easiest way to prescribe a pressure drop between inlet and outlet is to use the fan-boundary condition. I.e. in constant/polyMesh/blockMeshDict use e.g.
cyclic inout
    (4 7 3 0)
    (6 5 1 2)
Then in 0/U
  inout
    type cyclic;
    value uniform (0 0 0);
In 0/p write
inout
    type fan;
    patchType cyclic;
    f List<scalar> 1(-0.005); // p_OF = p_real / rho
    value uniform 0;
and mind that the OpenFOAM pressure is divided by the density in incompressible flow. The pressure drop (here 0.005*rho) that is needed for a certain mean velocity can be calculated by the Poisseuille number (if available) or must be guessed and then corrected. (Yes, I know there is channelFoam, but I cannot recommand that for various reasons.)
Here the "value"-entries are only used for the first iteration (and to prevent paraFoam from crashing) and are then overwritten.
Good luck!
sunliming, arvindpj, mgg and 2 others like this.
wenterodt is offline   Reply With Quote
Old   February 25, 2010, 04:58
Thomas Baumann is on a distinguished road
an other way is to use mapped boundary condtions.
http://www.cfd-online.com/Forums/ope...condition.html
Regards Thomas
sunliming likes this.
Thomas Baumann is offline   Reply With Quote
Old   February 27, 2010, 04:36
alireza
cyclic inout
    (4 7 3 0)
    (6 5 1 2)
Then in 0/U
  inout
    type cyclic;
In 0/p write
inout
    type fan;
    patchType cyclic;
    value uniform 0;
Good luck!
Dear Tammo
thanks for your help. but, I have some other questions. could you tell me, what is the Fan-boundary condition and is it possible to use this B.C in icoFoam. also, I want to know for laminar channel flow, can I use icoFoam?
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 15:06
Must periodic oscillation give periodic results? zonexo Main CFD Forum 6 May 13, 2007 16:36
periodic b.c. nick FLUENT 0 September 1, 2006 10:46
SYMMETRY + PERIODIC B.C....I need Help! JB FLUENT 6 January 14, 2005 08:03
About UDF of Inlet and Periodic B.C. JI Lucheng FLUENT 2 December 28, 2001 20:18
