Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam
Like Tree12Likes
  • 1 Post By mchurchf
  • 10 Post By alberto
  • 1 Post By alberto
Old   December 30, 2009, 18:56
Default Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam
Matthew J. Churchfield
mchurchf is on a distinguished road
To whom can help,
I am trying to reconcile some differences between pisoFoam and buoyantBoussinesqPisoFoam.
In the UEqn.H file of buoyantBoussinesqPisoFoam the following equation is set up to predict velocity:
UEqn
fvc::reconstruct((fvc::interpolate(rhok)*(g & mesh.Sf()) - fvc::snGrad(p)*mesh.magSf()))
However, in pisoFoam, this is the equation:
UEqn == -fvc::grad(p)
Aside from the inclusion of the gravity term in buoyantBoussinesqPisoFoam, why are the face values used to reconstruct the cell centered values, whereas in pisoFoam the cell center values are used directly?
The same situation occurs in setting up the pressure equation. In buoyantBoussinesqPisoFoam, the equation is:
volScalarField rUA("rUA", 1.0/UEqn.A());
surfaceScalarField rUAf("(1|A(U))", fvc::interpolate(rUA));
fvm::laplacian(rUAf, p) == fvc::div(phi)
whereas in pisoFoam, it is:
volScalarField rUA = 1.0/UEqn.A();
fvm::laplacian(rUA, p) == fvc::div(phi)
buoyantBoussinesqPisoFoam is solving for pressure on the faces, and pisoFoam is solving for cell centered pressure. Does this make a difference? Why are the two codes different in this manner?
Thank you
rajibroy likes this.
mchurchf is offline   Reply With Quote
Old   January 10, 2010, 18:27
Alberto Passalacqua
in pisoFoam you have the standard implementation, in buoyantBoussinesqPisoFoam the solution algorithm is modified as follows:
- you reconstruct the gravity and the pressure gradient contributions from the corresponding contribution to the flux
- you solve a "pseudo-staggered" version of the pressure equation
- you correct the flux
- you obtain the velocity correction reconstructing from the flux again (remember the flux is always continuous)
This technique tries to mimic a staggered grid arrangement. It is applied to the gravity term too, since it is included in the pressure equation.
Best,
Alberto
kaifu, MPJ, mechy and 7 others like this.
Alberto Passalacqua
Old   March 12, 2012, 07:12
Samuele Z
samiam1000 is on a distinguished road
Originally Posted by alberto View Post
Dear Alberto,
I am trying to understand the different solvers. So, for simpleFoam I've found this wiki..
As far as the pisoFoam is concerned, you wrote that it present the standard implementation.
What does this mean? Is there a reference page?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   March 12, 2012, 07:53
Alberto Passalacqua
Originally Posted by samiam1000 View Post
Dear Alberto,
Thanks a lot,
Samuele
Hi Samuele,
unfortunately I don't think there is a reference page. In pisoFoam you have the standard PISO algorithm you find in books, without body force term and without any particular treatment, except the Rhie-Chow interpolation. You can take a look at the icoFoam page on the wiki and you'll see many similarities.
My statement has to be read in the context of the comparison between the two solvers in the topic, where buoyantBoussinesqPisoFoam uses flux reconstruction to improve the solution procedure when body force terms are included.
Best,
Alberto Passalacqua
Old   March 12, 2012, 07:57
Samuele Z
That's great, thanks.
And what about the pimpleFoam solver? Do you know which solver is embedded in such a solver?
Thanks a lot,
Samuele
Old   March 12, 2012, 08:00
Alberto Passalacqua
The "pimple" solvers use a "combination of PISO and SIMPLE", which is not that far from the flavors you find in other codes with different names (unsteady SIMPLE, iterative PISO, depending on the creativity of the authors :-)).
In short, it is an iterative solution method with sub-iterations over the set of equations to improve the robustness of the algorithm using under-relaxation, and to speed-up transient simulations or perform pseudo-transient simulations.
Best,
samiam1000 likes this.
Alberto Passalacqua
Old   September 11, 2013, 00:24
Dongyue Li
sharonyue is on a distinguished road
Best,
Alberto
Dear Alberto,
Can I say that I have to reconstruct it when there is a body force? Is it a must?
for example, in interFoam's UEqn:
solve
            UEqn
            fvc::reconstruct
                    fvc::interpolate(interface.sigmaK())*fvc::snGrad(alpha1)
                  - ghf*fvc::snGrad(rho)
                  - fvc::snGrad(p_rgh)
                ) * mesh.magSf()
Can I code it like:
solve
            UEqn
                    interface.sigmaK()*fvc::grad(alpha1)
                  - ghf*fvc::grad(rho)
                  - fvc::grad(p_rgh)
sharonyue is offline   Reply With Quote
Old   August 6, 2023, 10:12
Reviewer #2
randolph is on a distinguished road
Best,
Alberto
Alberto,
What is the reason that this "pseudo-staggered" version of the pressure equation is not needed in the standard psioFoam, but needed by the buoyantBoussinesqPisoFoam?
Thanks,
Rdf
randolph is offline   Reply With Quote
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 13:44
Solution Method & turbulent intensity in CFX 5.5.1 hamza albazzaz CFX 7 June 29, 2011 13:39
Question about meshing / solution scheme of CFX Coriolius CFX 8 August 1, 2004 19:39
FVM,FDM AND FEM d Main CFD Forum 4 May 30, 2003 04:19
Trouble w. tri. FV method and lam. backstep flow Steve Reuss Main CFD Forum 12 December 26, 2001 12:47
