Defining Solid and Fluid zones in OpenFoam
Like Tree2Likes
  • 1 Post By foamcfd
  • 1 Post By santoo_cfd
Old   December 14, 2009, 01:11
Default Defining Solid and Fluid zones in OpenFoam
Yogesh Patil
foamcfd is on a distinguished road
Hi All,
I am solving conjugate heat transfer problem in which there are two zones i.e fluid and solid. Can anyone please tell me how I can separate the two zones in PolyMesh folder? Is there any other way of doing it. I am using the mesh which is generated in ICEM. I have successfully imported the mesh in foam.
onurcanpiskin likes this.
foamcfd is offline   Reply With Quote
Old   December 17, 2009, 07:02
santhosh
santoo_cfd is on a distinguished road
Somebody correct me If I am wrong--
If you have successfully imported mesh from ICEM. It should create cellZones and faceZones in constant/polyMesh directory (fluen3DMeshToFoam will do the job).
After that using splitMeshRegions -cellZones to create seperate regions. After this 0.001 directory will be created in which two directory corresponding to each fluid zone will be there.
For more information, check chtMultiRegionFoam directory.
santoo_cfd is offline   Reply With Quote
Theory behind the solid domain rotation in fluid using Bets property Riken CFX 0 October 28, 2009 10:51
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 06:36
conjugateHeatFoam: Should solid and fluid have the same mesh at the coupled boundary? awacs OpenFOAM Running, Solving & CFD 6 September 22, 2009 23:58
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 08:14
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 12:41
