How to compile a new utility
Like Tree3Likes
  • 3 Post By alberto
Old   December 12, 2009, 13:55
Unhappy How to compile a new utility
raul
rudy is on a distinguished road
I am new openfoam user and I am not good at programming . I intend to find grad of a scalar variable which is a solution of my computation . Initially I used a function "gradient of unstructured variable" from paraFoam but it is giving me some error.So I am trying to make my own utility to calculate gradient of scalar quantity.Now,I guess if I make a new utility i would have to compile it with my solver and for that I am following instructions given in Userguide.I mentioned utilityFunctionObjects lib name in solver/Make/options and then used wmake command from inside solver dir. I guess it goes on well and ultimately yields a messege that solver is uptodate,but when i use the new utility command name from inside case directory it says command is not found.Can anyone please tell me what exact steps I should take to compile my newly defined utility file with the intended solver.
Thanks and regards,
rudy.
rudy is offline   Reply With Quote
Old   December 12, 2009, 21:29
Alan Russell
AlanR is on a distinguished road
Rudy,
Some searching through the OF forums will turn up a number of links to courses, tutorials, etc that cover programming and customizing applications. Here's a link that may be helpful: http://www.openfoamworkshop.org/2009...ngTutorial.pdf. A recent thread has an excellent list of links. http://www.cfd-online.com/Forums/ope...thingelse.html. Learning Foam is challenging, but it's worth the effort.
Good luck, Alan
AlanR is offline   Reply With Quote
Old   December 13, 2009, 01:42
Alberto Passalacqua
Originally Posted by rudy View Post
Thanks and regards,
rudy.
Take a look at laplacianFoam. In write.H gradients of the temperature are computed and stored. The procedure is general.
To sum it up
  • Compute the gradient vector and store it in a volVectorField as in
volVectorField gradT = fvc::grad(T);
  • You can decompose the gradient in its components too, storing them in separate files. For example for the x component, which will be stored in a file called "gradTx", you can use:
volScalarField gradTx
            IOobject
                "gradTx",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            gradT.component(vector::X)
Note that
  • the instructions are enclosed in an if whose condition is runTime.outputTime(), which means that fields will be written when a set of data will be automatically saved by the solver
  • the gradient components are stored, but the gradient vector field is not stored. To do that simply add th following line after the definition of gradT:
 gradT.write();
You can edit your code adding similar lines for the variable of your interest, and then rebuild the application with
wmake
in the directory containing the source code.
I hope this help.
Best,
Alberto
P.S. Simple answers to simple questions! Sometime a "search for it" simply does not work, especially for new users.
elvis, tfuwa and y_jiang like this.
Alberto Passalacqua
Old   December 14, 2009, 09:43
raul
Thanks a lot to both of u, I did develop my own utility to find gradient using ur instructions and it's working now...
regards,
rudy
Old   October 1, 2011, 23:48
doubtsincfd is on a distinguished road
gradT.write(); returns a zeroGradient field for patches. But the field is non-zero in component files like gradTx. Why?
doubtsincfd is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 03:00
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 14:24
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 22:51
Help for udf compile error richard FLUENT 3 October 13, 2003 00:13
