October 14, 2009, 14:02 |
problems with pow(scalar, double)
Sven Degner
Rep Power: 17 |
Hi Foamers,
i got a problem with the mathcalls.h especially with the pow() funktion. In my case I need a pow(scalar, double) function: scalar area1 = gSum(mesh.magSf().boundaryField()[0]);//Fläche des Pätches inlet scalar sumFieldp0 = gSum(mesh.magSf().boundaryField()[0]*p.boundaryField()[0]) / area1; scalar area2 = gSum(mesh.magSf().boundaryField()[1]);//Fläche eines Pätches outlets scalar sumFieldp1 = gSum( mesh.magSf().boundaryField()[1] * p.boundaryField()[1] ) / area2; //Temperatur eines Pätches outlets scalar Temp2 = gSum( mesh.magSf().boundaryField()[1] * T.boundaryField()[1] ) / area2; scalar sumField = sumFieldp0 + sumFieldp1; scalar Gaskonstante = 259.8;//Gaskonstante Luft = 259.8 scalar X = pow(sumField, 0.4); ERROR buoyantBoussinesqSimpleFoam_alphak.C: In function 'int main(int, char**)': buoyantBoussinesqSimpleFoam_alphak.C:103: error: call of overloaded 'pow(Foam::scalar&, double)' is ambiguous /usr/include/bits/mathcalls.h:154: note: candidates are: double pow(double, double) The errror seems clear, the pow-function with a scalar and double. But how can I solve it? Thanks Sven |
October 14, 2009, 14:25 |
Mathieu Olivier
Rep Power: 17 |
Hi Sven,
Let me suggest you something. Replace the line : scalar X = pow(sumField, 0.4); by: scalar X = Foam::pow(sumField, 0.4); Mathieu |
October 15, 2009, 05:50 |
Sven Degner
Rep Power: 17 |
Thanks Mathieu,
it works |
December 13, 2017, 14:28 |
Clint
Rep Power: 11 |
Fixed my problem too thank you! But I'm a little confused. Does this mean that there are other pow() functions outside of the Foam namespace that also take those parameter types (scalar, double)?
New densitybased solver AeroFoam | giulio_romanelli | OpenFOAM Running, Solving & CFD | 48 | January 15, 2016 09:20 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
Parallel rasInterFoam | openfoam_user | OpenFOAM Running, Solving & CFD | 4 | November 1, 2008 05:14 |
what's wrong about my code for 2d burgers equation | morxio | Main CFD Forum | 3 | April 27, 2007 11:38 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
