Time history of a variable at a point for calculating correlations?
Like Tree1Likes
  • 1 Post By gschaider
Old   August 25, 2009, 15:08
Default Time history of a variable at a point for calculating correlations?
Eoin
eoin is on a distinguished road
Hi everyone, Is there any utility available to convert openfoam output data into files corresponding to each individual grid point which contain the time history of a flow variable at that point? What i want to do is calculate two point correlation functions between various grid points. Alternatively, is there maybe an easy way of doing this? Thanks,
eoin is offline   Reply With Quote
Old   August 25, 2009, 17:07
Assistant Moderator
Bernhard Gschaider
Well the value of the cell N is always the (N+1)th value in the internalField. So you could always write a program/script that gets the Nth value from all the data files of that field.
If you're more a point-and-click person, have a look at the Temporal filters in paraview. If you view data in the spreadsheetview and export you get CSV-files which can be read by any spreadsheet-program. Of course you don't want to do that for all the cells of the mesh
(But I don't know how well this works for time-series, you'll have to try for yourself)
Bernhard
songwukong likes this.
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 23:05
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 16:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
