STL to gmsh
Like Tree2Likes
  • 1 Post By nomad
  • 1 Post By elorriaux
Old   August 5, 2009, 16:39
Default STL to gmsh
John
nomad is on a distinguished road
I'm trying to import a simple 3-d cube from SolidWorks (saved as STL) into gmsh, but I get the error:
'No facets found in STL file for solid 0'
I would eventually like to import complex structures into gmsh.
Please help.
Thanks.
sourav90 likes this.
nomad is offline   Reply With Quote
Old   August 5, 2009, 19:22
John
The STL that is saved in SolidWorks has a weird wireframe as can be seen in the attachment. Is there any way of deleting the diagonal lines that extend from the cylinder to the corners of the block so that they don't have to be deleted individually in gmsh.
Also, gmsh assigns a uniform mesh. Is there a way to refine the mesh in gmsh so that it is finer around the cylinder, or would I have to do this in OpenFOAM.
Thanks.
Old   August 10, 2009, 05:09
Etienne Lorriaux
elorriaux is on a distinguished road
Originally Posted by nomad View Post
The diagonal lines are necessary to describe your circle curves, that's the basis principle of STL format.
I am regularly loading STL surfaces (generated with OCC) into gmsh without any problems. Maybe there is a little problem with the Solidworks STL export. Are you using Gmsh under Linux ? If so, don't forget to launch a dos2unix on your STL file.
If you compile gmsh with OCC support, you can also load your surfaces in gmsh as STEP or IGES files.
Thanks.
Concerning your case, i think it will be a lot faster to draw your front plane in gmsh subdivided in 4 surfaces. Then you will be able to get a structured mesh with a nice grading from your cylinder for the boundary layer. You just have to extrude the mesh in gmsh and define entities before converting the mesh to OF.
Your case can also be easily meshed in OF with blockMesh.
Regards, Etienne.
elorriaux is offline   Reply With Quote
error, facets, gmsh, stl
[surface handling] How to make boundary patches in STL file nzy102 OpenFOAM Meshing & Mesh Conversion 4 January 22, 2018 16:03
CAD -> gMsh -> enGrid -> OpenFOAM Problem AlGates OpenFOAM 7 August 6, 2010 13:46
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 20:51
[Gmsh] How does Gmsh deal with overlap boundaries? yuhai OpenFOAM Meshing & Mesh Conversion 1 April 24, 2009 14:34
Importing and cleaning STL files Peter FLUENT 2 October 13, 2006 06:41
