change angle of attack in aerofoil
Like Tree3Likes
  • 1 Post By naveen
  • 2 Post By naveen
Old   July 23, 2009, 16:46
Default change angle of attack in aerofoil
nicchani is on a distinguished road
Hi, I would like to know if it is possible to change the angle of attack of an aerofoil in OpenFOAM. I've been told that it's possible in Fluent so I guess there must be something similar in OpenFOAM. Thanks!
nicchani is offline   Reply With Quote
Old   July 26, 2009, 04:42
Mehrdad is on a distinguished road
I am not an experienced user of OpenFOAM. But, I think It is just a matter of changing your B.Cs in the OpenFOAM.
Good luck
Mehrdad is offline   Reply With Quote
Old   August 4, 2009, 05:29
Default angle of attack
NAVEEN.K.M
naveen is on a distinguished road
hi nicchani
Hi, yes it is possible to change the angle of attack of an aerofoil in OpenFOAM too like fluent. just change in the 0 directory there is file named called velocity "u", just change according to your velocity like 51*cos(2) along x direction and 51*sin(2) along y direction as u required for different angle of attacks ( example i have given 2 is the angle of attack) calculate from these cos and sin put those values in the file "u"....
silver.blaze likes this.
naveen is offline   Reply With Quote
Old   August 4, 2009, 06:09
ok, thanks to both of you for your help! I will try the sin and cos method
Old   April 4, 2012, 09:42
deepaktbabu
deepaktbabu is on a distinguished road
hey naveen,
why is 51 there in the equation ?
deepaktbabu is offline   Reply With Quote
Old   April 5, 2012, 23:40
NAVEEN.K.M
dear deepaktbabu,
It is the velocity what you are taking from Mach number...just i have given velocity reference for mach number at 0.3...you can give ur velocity depends on ur mach number..
deepaktbabu and s.m like this.
Old   April 6, 2012, 06:39
deepaktbabu
thank you
Old   March 16, 2013, 09:08
AndreiCFD
andrei.cimpoeru is on a distinguished road
I am not quiet sure because one will be bigger and one will be lower for example the cos bit is bigger than the sin bit.......
andrei.cimpoeru is offline   Reply With Quote
Old   July 11, 2013, 16:06
s.m
saeideh mohamadi
s.m is on a distinguished road
Originally Posted by naveen View Post
dear deepaktbabu,
Dear Naveen, when we have three element airfoil, we should add the angle of attack to deflection angle of each of them,e.g the main element has 0 degree angle and the flap(another element of three element airfoil) has 30 degree angle.
what should we write for liftDir and dragDir in controlDict according to their angles?
s.m is offline   Reply With Quote
Old   November 14, 2020, 05:51
Default Angle of attack for LES in openfoam using pointwise mesh
lam
najiba.ae.mist@gmail.com is on a distinguished road
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 8
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type turbulentInlet;
referenceField uniform (10 0 0);
fluctuationScale (0.02 0.01 0.01);
value uniform (10 0 0);
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0 0 0);
upperWall
type noSlip;
lowerWall
type noSlip;
frontAndBack
type empty;
if this my u file should i put values ucos2 and usin2 for AOA=2? in the highlighted part only ?
najiba.ae.mist@gmail.com is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
introducing angle of attack on ICEMCFD HEXA icem beginner CFX 2 December 24, 2008 12:00
introducing angle of attack on ICEMCFD HEXA icem beginner Main CFD Forum 3 December 17, 2008 06:05
angle of attack with icem hexa icem beginner Main CFD Forum 0 December 5, 2008 17:54
angle of attack kiran FLUENT 0 September 10, 2004 09:18
