Importing SolidWorks Model DIRECTLY into openfoam
Like Tree1Likes
  • 1 Post By hellorishi
Old   July 20, 2009, 21:44
Default Importing SolidWorks Model DIRECTLY into openfoam
Brad
bgood44 is on a distinguished road
Hello All,
I am currently working on developing a UAV for a university project. Unfortunately, the wind tunnels at my school aren't quite big enough for this uav and I don't want to go through the hassle of building a scale model. I have a very accurate SolidWorks model of the aircraft and would like to use OpenFoam to do some analysis ( specifically, I want to find the control derivitives, so essentially I just need to find the pressure distribution on the surface of the aircraft).
Is there a way I can use my SolidWorks model and generate a mesh using an open source software, and than use openfoam to find the pressure distribution on the aircraft. I would prefer to use openfoam ( Its a software I really want to learn), and I would like to use my current SolidWorks model. I know cosmos is an option with solidworks, but I would prefer not to go that route, so please don't go there...
Thanks for the Help!
bgood44 is offline   Reply With Quote
Old   July 21, 2009, 02:59
Rishi .
hellorishi is on a distinguished road
Hello Brad,
There are a few opensource meshing tools for OpenFOAM. You might have to export Solidwork file as STL for snappyHexMesh
http://www.opencfd.co.uk/openfoam/do...pyHexMesh.html
Or IGES /STEP for NetGen or Gmsh
http://www.hpfem.jku.at/netgen/
http://www.geuz.org/gmsh/
I am not sure if one can get boundary layers with NetGen or Gmsh.
SnappyHexMesh does that, but I find it a bit complicated to use.
tutorial->
http://www.tfd.chalmers.se/~hani/kur...ppyHexMesh.pdf
hellorishi is offline   Reply With Quote
Old   July 21, 2009, 03:05
Rishi .
I forgot to mention EnGrid.
http://www.ohloh.net/p/engrid
I have not tested this one yet. Seems promising.
Old   July 22, 2009, 12:48
Brad
And all of the programs you listed work with solidworks? Is there any downside to using Engrid, NetGen, or Gmsh with solidworks ?
Old   July 23, 2009, 05:45
Rishi .
These programs work with generic file formats like STL, IGES /STEP
Solidworks or almost any CAD package can export to the above 3 formats.
The downside of exporting to such formats is slight loss of accuracy in shape, due to approximations. e.g. it might export a circle as a 10sided polygon. You can increase the accuracy by exporting as 36 sided polygon for better approxitmation.
Old   July 23, 2009, 18:53
Brad
When I download OpenFoam, do these programs come with it or do I need to add it seperately
Thanks,
Brad
Old   July 24, 2009, 02:27
Rishi .
snappyHexMesh is native OpenFOAM.
Others have to be downloaded separately...
ironsamosa likes this.
Old   December 31, 2018, 21:18
Default importing solidworks model to openFOAM
Henry Keller
ironsamosa is on a distinguished road
Hi there, would you be kind enough to guide with with what command line statements on how to import a Solidworks or Inventor model or assembly into OpenFoam, then meshing it and then opening in on paraview?
thanks!
ironsamosa is offline   Reply With Quote
Old   January 18, 2019, 04:27
Zander Meiring
yambanshee is on a distinguished road
thanks!
A good source is this: http://sourceflux.de/blog/tag/snappyhexmesh/
Long answer is; it's not just a little bit of command line work. Generating a good mesh with open source software is often quite challenging.
yambanshee is offline   Reply With Quote
Old   January 20, 2020, 07:47
Masoumeh
ms.hashempour is on a distinguished road
Dear guys
I have solidworks tunnel shape. But I cant using salome. It hangs on and stops working.
What sould I do?
ms.hashempour is offline   Reply With Quote
Importing Solidworks Assembly rmc CFX 3 September 30, 2014 11:34
Fluent OpenFoam comparison kepsilon model alimansouri OpenFOAM Running, Solving & CFD 5 January 19, 2009 10:35
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 06:26
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 11, 2007 00:23
Does OpenFoam have a HybridURANS model andycong OpenFOAM Running, Solving & CFD 2 February 16, 2006 22:20
